[SOLVED] 4.7 Beta2/Beta3 Playlist Import Issue
Postby MadEvil » Wed Aug 01, 2012 4:50 pm
Hi Sindre,
I have spotted an other issue with Playlist import with SS 4.7 Beta2/4.7 Trunk Build.
i hope you can also reproduced this problem:
1) Make Playlist with 4.6/4.7 Release
2) Fresh Install 4.7 (clean Database)
3) Autoimport works well, all Playlists are there
4) make new Mediafile Scan
5) all Playlists gets empty
6) manually reimport the Playlist work until i rescan
have someone else seen this issue?
Best regards
Madsonic Developer
MadEvil
Re: [SOLVED] 4.7 Beta2/Beta3 Playlist Import Issue
Postby MadEvil » Wed Aug 01, 2012 6:35 pm
I found the issue within the Playlist.
i mixed the paths, example Playlist path D:\music\... with subsonic settings d:\music\....
this should be fixed to be case insensitive.
Best regards
Madsonic Developer
MadEvil
Postby mystery666 » Wed Aug 22, 2012 1:59 pm
I'm so annoyed that I haven't had playlists for weeks because of something so simple. Thanks for figuring it out!
mystery666
Postby BKKKPewsey » Wed Aug 22, 2012 5:15 pm
MadEvil wrote:i mixed the paths, example Playlist path D:\music\... with subsonic settings d:\music\....
Well done for spotting that and thanks for mystery for bumping it as I missed the post.
I just checked my playlists and indeed I did have a case problem (MYSERVER-NAME vs Myserver-Name)
So I just deleted and re-imported those playlists - see what happens tomorrow :roll:
Postby okieeagle » Sun Aug 26, 2012 7:32 pm
So, what happened? I corrected some case sensitive paths and till don't see any files after importing the playlist.
okieeagle
Users browsing this forum: No registered users and 68 guests
