SubAir: Can't order playlist after sort
Postby lprager@compup.com » Wed Aug 25, 2010 5:19 pm
I found a problem in SubAir with the playlists. If you sort a current playlist (by clicking the column header), there is no way to stop sorting a playlist.
So, if you try to reorder a playlist, or load a new playlist and play it in its original order, you can't. It will only play in the original order.
It looks like we need a button to clear the sorts.
The only way to resolve the problem now is to close the program and reload.
There also seems to be some other glitch. If I click a track, say the second in the list, it will play the second track then go back to the first and repeat.
I am using v0.031.
Thanx,
Lance
lprager@compup.com
