First - fantastic mod to a great program. I am extremely thankful for your great work!
My installation seems to have a bug whereby not all of the selections on the tag configuration page are saved when you hit "Save". For instance, I can't get it to keep "Rock" selected. On the other hand it seems fine with "techno". There's a real mix of which ones will work and which ones won't, although if I hit "Mark All" (it initially correctly marks them all) and then "Save", it only saves the marks to the first 30 or so genres listed alphabetically but leaves the remainder (with the exception of some of the ones further down the list that it has previously saved, e.g. "techno"). I've checked both subsonic.log and musiccabinet.log for any error messages around the time of the unsuccessful save, but there's nothing.
Any ideas?
In case it is relevant, I have a fairly large collection (>100k tracks).
Kind regards
pw22
