Artwork
Artwork
Postby Niklas_71 » Fri Jan 18, 2013 2:39 pm
Hi, I have problem with the album covers. I have mostly local covers that I want to use. Prefer last.fm artwork is set to No and I did a Full scan. But most of my covers doesnt show. Any suggestion? Didnt have problem with that before I installed MusicCabinet.
//Niklas
Niklas_71
Re: Artwork
Postby hakko » Fri Jan 18, 2013 2:55 pm
Is your folder artwork placed in the same directory/directories as the files that make up an album? Is it called folder.jpg/jpeg/png/gif or cover.jpg/jpeg/png/gif?
MusicCabinet developer
hakko
Re: Artwork
Postby Niklas_71 » Fri Jan 18, 2013 3:08 pm
I have the jpg file in the same folder as the mp3 files, is that wrong?
Niklas_71
Re: Artwork
Postby hakko » Fri Jan 18, 2013 3:13 pm
That's perfectly fine. Is it called folder.jpg or cover.jpg?
hakko
Re: Artwork
Postby hakko » Fri Jan 18, 2013 3:16 pm
And you don't have embedded art in your mp3 files? If just one mp3 file has embedded artwork, that is used instead of the folder artwork.
hakko
Re: Artwork
Postby Niklas_71 » Fri Jan 18, 2013 3:24 pm
I have different name, does it have the be called cover or folder?
Niklas_71
Re: Artwork
Postby hakko » Fri Jan 18, 2013 3:30 pm
You either have to call it:
or insert your custom file name into the database and scan again. Check the table library.coverartfilename, it contains allowed file names and their priority (which one to use if multiple matches are found).
hakko
Re: Artwork
Postby Niklas_71 » Fri Jan 18, 2013 5:58 pm
Thanks alot for a quick response, now I understand what I did wrong...
Tack för en jäkligt bra program o allt jobb du lägger ner... ;-)
Niklas_71
Re: Artwork
Postby hakko » Fri Jan 18, 2013 6:00 pm
gött! varsågod :)
hakko
Return to MusicCabinet
