MusicCabinet Settings
Postby Jfass » Wed Feb 06, 2013 2:43 pm
Hello, I am new to MusicCabinet, I have been using Subsonic for years and I love it. After the initial setup there were some settings that I could play with under settings - MusicCabinet. But today (24 hours after install) when I go to the MusicCabinet settings all I have the option to do is update the search index. So I updated the search index thinking that after it is complete the settings would come back up, but this did not happen. after it says it is complete I refresh and the same button is there saying that the search index is ready to be updated.
How do I get to the MusicCabinet settings now?
Jfass
Re: MusicCabinet Settings
Postby hakko » Wed Feb 06, 2013 8:41 pm
That sounds like a bug to me.. not the best start I could give you. Do you mind sending the musiccabinet.log file (location found from About view) and restarting the service?
MusicCabinet developer
hakko
Postby Jfass » Wed Feb 06, 2013 8:59 pm
Thanks for taking a look hakko!
Here is the log right after I shut it down and restarted it and did a re-index.
[2013-02-06 15:52:49] INFO PlaylistGeneratorService - MusicCabinet playlist service started at Wed Feb 06 15:52:49 EST 2013.
[2013-02-06 15:52:51] DEBUG DatabaseAdministrationService - databaseUpdated = true
[2013-02-06 15:52:51] DEBUG DatabaseAdministrationService - databaseCreated = true
[2013-02-06 15:52:57] DEBUG PlaylistGeneratorService - allowed radio song length interval (45, 0)
[2013-02-06 15:53:23] DEBUG PlaylistGeneratorService - allowed radio song length interval (45, 0)
[2013-02-06 15:53:23] INFO LibraryUpdateService - Starting library update. Scan [\\DISKSTATION\Music], offline = false
[2013-02-06 15:54:33] DEBUG JdbcLibraryDeletionDao - delete_from_library(): 351 ms
[2013-02-06 15:54:33] DEBUG JdbcLibraryAdditionDao - add_to_library(): 498 ms
[2013-02-06 15:54:33] INFO LibraryUpdateService - Library scanned in 69 seconds.
[2013-02-06 15:54:33] DEBUG LibraryUpdateService - Check if last.fm can be looked up...
[2013-02-06 15:54:33] DEBUG LibraryUpdateService - That went well, return true.
[2013-02-06 15:54:33] DEBUG LibraryUpdateService - Starting last.fm update.
[2013-02-06 15:54:33] DEBUG UserRecommendedArtistsService - allowed: false, successful: false, errorCode: 0, errorMessage: null, errorRecoverable: false, responseBody: null
[2013-02-06 15:54:34] INFO LibraryUpdateService - 24 artist relations.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 24 artist top tracks.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 24 artist tags.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 24 artist biographies.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 14 album descriptions.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 0 tag descriptions.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 0 weekly group artist charts.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 0 tag top artists.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 4 user top artist periods.
[2013-02-06 15:54:34] INFO LibraryUpdateService - 1 user recommended artists.
[2013-02-06 15:54:34] INFO LibraryUpdateService - -1 scrobbled tracks statistics.
[2013-02-06 15:54:34] INFO LibraryUpdateService - In total, 115 last.fm operations done in 0 sec.
[2013-02-06 15:54:34] INFO PlaylistGeneratorService - Creating materialized view took 0 sec.
[2013-02-06 15:54:34] INFO LibraryUpdateService - Finishing library update.
Jfass
Postby hakko » Wed Feb 06, 2013 9:22 pm
Nothing wrong in there, I guess whatever went wrong must have happened earlier.. after you've restarted the service, what happens if you go to Settings -> MusicCabinet?
hakko
Postby Jfass » Wed Feb 06, 2013 9:26 pm
The same thing that is there now:
MusicCabinet configuration
MusicCabinet is now ready to scan your library, and fetch meta-data from last.fm. Depending on the size of your library, this could take a while, as they have some regulations on data traffic. A rough estimate is 30 minutes per 10.000 tracks.
You can use the simplified file-based interface to access your music during the import.
These folders will be scanned:
Music2
Then the Button "Update search index now"
Jfass
Postby hakko » Wed Feb 06, 2013 10:03 pm
How much music do you have? Is this just a small test or have you added your full library? Does the "Play top tracks" work for your most popular artist, for example? (Yes, I am confused)
hakko
Postby Jfass » Wed Feb 06, 2013 10:12 pm
This is my full library, about 14,000 songs. I am not sure what you mean by "Play top tracks" I do not see that on any of the artist's pages. Just "Play All" "Play Random" and the selector for Play/Enqueue/add and then "edit". I also wasn't able to get the radio to play if that helps at all.
Jfass
Postby hakko » Wed Feb 06, 2013 10:26 pm
It surely does sound as the last.fm import has failed completely, so that there's no additional information to present per artist. It's supposed to look like this: http://dilerium.se/musiccabinet/images/artistradio.png
I'm confused by this as well from your log file: "In total, 115 last.fm operations done in 0 sec". That shouldn't be possible...
If you go back to Settings -> Media folders, do you have the option to run a Normal scan or a Full scan?
hakko
Postby Jfass » Wed Feb 06, 2013 10:30 pm
Yes, I have the option to do Offline, Normal, and Full, and I have done all three. Maybe when I get home from work I will uninstall and do a re-install. Do you think that might repair it?
Jfass
Postby hakko » Wed Feb 06, 2013 10:54 pm
It's worth trying, I'm out of ideas. If you do, please paste the musiccabinet.log file here, hopefully it'll give some clue.
hakko
Postby Jfass » Thu Feb 07, 2013 2:19 am
So I uninstalled Subsonic, uninstalled PostgreSQL, re-installed PostgreSQL, and re-installed Subsonic from the MusicCabinet download. Ran through all the setups fine, it took a long time to run through the indexing, so I was expecting it to work but to no avail.
Here is my log:
https://docs.google.com/file/d/0BypKOEEiMwH4U0duaWtDekluT0E/edit?usp=sharing
I don't know what else to do. Is there a way to get rid of any evidence of Subsonic to start fresh? Maybe that will work? I just really want it to work because what I have so far is pretty awesome and what I see that it can do is even better. Plus with this being such a young project, I can only see it getting better with age!
Jfass
Postby shadow.8 » Thu Feb 07, 2013 2:25 am
[2013-02-06 19:47:57] WARN JdbcDatabaseAdministrationDao - Password validation failed. org.postgresql.util.PSQLException: FATAL: password authentication failed for user "postgres"
My guess is that is the problem. Did you change the password after re-installing?
676 artists
2,348 albums
26,738 songs
276.51 GB (~ 1,993 hours)
shadow.8
Postby Jfass » Thu Feb 07, 2013 3:19 am
I did, but I thought I had updated it correctly on both ends. I will try it again tomorrow doing the same method of un installing everything.
Jfass
Postby hakko » Thu Feb 07, 2013 8:17 am
If you've changed your credentials, you might want to remove the line MusicCabinetJDBCPassword=... from C:\Subsonic\subsonic.properties.
hakko
Postby Jfass » Thu Feb 07, 2013 2:05 pm
OK, It appears to be working now. Uninstalled PostgreSQL and re-installed with previous password, deleted the line MusicCabinetJDBCPassword=.... and I also changed MusicCabinetRadioMaximumSongLength=0 back to 600. I wonder if the maximum song length was the culprit from the very beginning?
Now I just need to find out why some music isn't showing up when it did for regular Subsonic....
Thanks for all your help!
Jfass
Return to MusicCabinet
