Thank you, but when I download setup.exe and install SubWiji, I always get .126 instead of .127.
Btw, what's the best way to do an update?
hulmgulm wrote:I found a problem with SubWiji:
I start is and it is using 37MB of memory. Then I use the X to close it and it starts to grab more and more RAM up to 1.6GB until it finally closes.
I use it on Win7 SP1 Enterprise english on a 8-Core Xeon machine with 12GB of RAM.
hulmgulm wrote:Thank you, but when I download setup.exe and install SubWiji, I always get .126 instead of .127.
hulmgulm wrote:Do you have a default My Music folder set?
* I'm not sure where I can set this
paulodell wrote:SubWiji will check for an update every 1/2hour automatically (if open), but the best way to guarantee an update is to close SubWiji and re-open, when it opens it does a check for the latest version straight away
Also if you go to http://dl.dropbox.com/u/2432141/Subwiji ... ubWiji.htm and click install it will install over the top the new version and keep your settings.
paulodell wrote:Its a default in Windows, if you can see Documents > My Music then its there. If the Cover Art flag doesnt help then it is not relating to the My Music folder.
Have you setup your server correctly?
Can you see the album mixer covers? (click the Music Mixer icon).
hulmgulm wrote:paulodell wrote:SubWiji will check for an update every 1/2hour automatically (if open), but the best way to guarantee an update is to close SubWiji and re-open, when it opens it does a check for the latest version straight away
I restarted SubWiji now several times, as well as I downloaded and ran the setup.exe several times too. But I'm still stuck with .126
I don't know if, beeing behind a proxy, might be the problem because the initial installation worked fine and I am able to play songs.
hulmgulm wrote:paulodell wrote:Its a default in Windows, if you can see Documents > My Music then its there. If the Cover Art flag doesnt help then it is not relating to the My Music folder.
The My Music folder is there and I can see the covers in the Music Mixer.
I think that I setup my server correctly, as I can use it with the web interface and the subsonic gadged and the Andriod app.
paulodell wrote:If you go here...http://dl.dropbox.com/u/2432141/Subwiji ... ubWiji.htm does the version say 0.1.0.126, 0.1.0.127 or 0.1.0.128?
If it doesn't then there is something blocked by your proxy, please load that url in IE and click Install from there, I have forced another build to see if that helps also.
hulmgulm wrote:I had to switch to the third and last proxy know to me to get the latest update. It looks like the grabbing of memory is gone.
Thank you for fixing this so fast!
DGMayor wrote:Hey - I recently switched to this because for some reason SubAir decided to stop trying to connect to my server. Anyways, so far so good for the most part, but the main issue I'm having is if I pause the music, when I resume, it plays for a bit, but then goes quiet. Time still ticks through the end of the song length and the next will play, but it happens every single time I pause it.
I had almost the reverse issue with SubAir. I would pause it and depending on how long I paused it for (say 30 seconds), it would wait 30 seconds before it started playing again.
