neodawg wrote:Looks good, seems to work fine. Can you possibly add an option to disable the 'now playing' popup window that shows up each time a song starts?
Hi Neodawg,
I will add an option in the settings to disable the popup tomorrow
good idea!
neodawg wrote:When searching again after a previous search the Artist tab doesnt refresh, you must click the green button on the tab (perhaps this is by design)
ah good spot, I will fix this.
neodawg wrote:Have the ability to have the player free floating on the desktop... (just found the auto hide feature) (possible bug with that, when docked to bottom and trying to change auto hide setting i was unable to enable it, switching back to top it works fine and I was able to enable it)
The free floating design is atm not in the list but I will add it for consideration, as for the auto hide whilst docked to the bottom of the screen I have intentionally not allowed the two to be used at the same time as it was causing major UI issues. There is a plan to enable it further down the line.
neodawg wrote:When searching on the Artist page, the album art is 'squished' the 'cd case' is causing the art to be tall and no longer square, possibly not have the 'cd case' or make it a bit wider so it will fit a square picture in it, ie 100x100 pixels.
I will have a look at modifying the dimensions of the cd case to out it back square again.
neodawg wrote:Perhaps, it would be possible to add the chat feature in, if that was there wouldnt be any reason to login to the default web interface
The chat feature is available as a secret window
(Alt + C) if you want give it a try. Please bear in mind that this chat window is in v v early beta stages, if you have an questions about the chat window itself please PM me about that
Paul
