Madsonic - Mashup Mod (old Support Thread)
Re: Technical Preview: Subsonic Mashup Mod 4.7
Postby GJ51 » Mon Sep 03, 2012 10:43 pm
Installed and testing!
Android video works properly.
Similar Artist view working.
Search never bothered me - I never could understand some users fixation with search and year and all those kinds of things, i've got about 60k tracks and never have trouble finding what I'm looking for in any version of SS; but that's just me I'm sure- LOL.
Zoom and bounce still has a few quircks in Chrome when zoomed above 100% - Left panel scroll bar overshoots the bottom and the mouse movement works when the pointer is in the column without holding the left button down. I actually kinda like that behavior. Frame resizing is disabled at 110& and 125%. once when i first tried the 125% there was the bounce effect, but then the column started overshooting the bottom and the bounce thing was no longer evident.
Not a big deal as I just do the adjusting at 100% then zoom up if I need to.
I also noticed an occasional darkening of the Main window. I'm not sure what I'm doing that triggers it, bit I'll repost if I can reproduce it consistently. Again, a minor issue.
This builds a keeper for me!
Postby MadEvil » Mon Sep 03, 2012 11:04 pm
GJ51 wrote:Installed and testing!
this sounds great :D
GJ51 wrote:Search never bothered me - I never could understand some users fixation with search and year and all those kinds of things, i've got about 60k tracks and never have trouble finding what I'm looking for in any version of SS; but that's just me I'm sure- LOL.
The Default Searchengine was a little to restricted (results,wildcards,...) but now its bigger an better. Now i like it! :wink:
GJ51 wrote:Zoom and bounce still has a few quircks in Chrome when zoomed above 100% - Left panel scroll bar overshoots the bottom and the mouse movement works when the pointer is in the column without holding the left button down. I actually kinda like that behavior. Frame resizing is disabled at 110& and 125%. once when i first tried the 125% there was the bounce effect, but then the column started overshooting the bottom and the bounce thing was no longer evident.
well, its a problem beyond 100% and at the moment i have no clue to fix this in the chrome browser, but I'm not giving up.
GJ51 wrote:I also noticed an occasional darkening of the Main window. I'm not sure what I'm doing that triggers it, bit I'll repost if I can reproduce it consistently. Again, a minor issue.
This is new, does this happen on a special theme? a screenshot would be great!
PS: many thanks for your tests :!:
best regards
Madsonic Developer
MadEvil
Postby GJ51 » Mon Sep 03, 2012 11:30 pm
that's the problem, I haven't been able to reproduce it on purpose after I saw it a few times. I always use Back in Black and I'll never go back! :mrgreen:
Postby gacopl » Tue Sep 04, 2012 7:43 am
Thank you for fixing android player. There's one more thing that keeps bugging me on mashup mod, when u use minisub in some views where should be album title is 'undefined' error
gacopl
Postby Magica » Tue Sep 04, 2012 2:51 pm
I upgraded my laptop to fedora 17 and 3100 version worked quit good. Only major problem is jumping video file forward. I think that is ffmpeg related. When you jump for example 5 minutes forward the loading icon circles long time before video continues playing.
So mod needs to be installed in Fedora 17 to get it work properly? If so I have to upgrade my primary server from 16 to 17. No big deal, it only takes little over hour to do that.
Allthough I installed newest Windows version today and there is a same problem with videos. I replaced ffmpeg from the original beta3 release and the problem is gone! So I think same method works with .rpm install.
Everythink else worked very good!
Could you upload .rpm version of this newest mod or are you planning to release new version in near future?
Thanks for you great work!
-m-
Magica
Postby MadEvil » Tue Sep 04, 2012 9:34 pm
New Build: 3106 (Beta3)
NEW: Update 'Back in Black' Theme issues
NEW: Include MiniSub 2.0.6
NEW: fixed REST API for MiniSub
NEW: fixed Similar Artists CSS Styles
NEW: finally fixed jumping & bouncing Scrollbar
NEW: Prevent Player Cache Issues
NEW: Update Linux ffmpeg - 20120904-static.32bit
NEW: Update Windows ffmpeg - 20120903-git-5d55830-win32-static
Download look @ first Post -> viewtopic.php?f=8&t=9187
Madsonic Developer
MadEvil
Postby GJ51 » Wed Sep 05, 2012 3:15 am
I haven't tested everything yet, but it's installed. I'll let you know if I notice anything.
EDIT: Looks pretty good. The only issue I see is the resizing of the frames in Chrome only works if the zoom is at 100%. Not a big deal.
This mod is very stable and functional. It's easy to update and has great features.
Keep up the great work.
Postby MadEvil » Wed Sep 05, 2012 9:13 am
GJ51 wrote:I haven't tested everything yet, but it's installed. I'll let you know if I notice anything.
Well this sound good! :D
As workaround a recommend Firefox till i found a solution for Chrome and frame resize over 100% zoom.
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Wed Sep 05, 2012 9:26 am
Announcement: Madsonic Android Client
Coming soon ...
NEW: extended REST API
NEW: Hot Rated Support
NEW: Star Support
NEW: many more
Best regards
Image Image Image
Madsonic Developer
MadEvil
Postby gacopl » Wed Sep 05, 2012 12:34 pm
Man you're doing tremendous job 20E (20 is really a lot in my country so imagine my gratefulness :) ) is going out for you, as it comes to android client there were few things that always pissed me in the original:
*play pause next prev buttons they are ugly and completely do nto fit into rest of the skin
*it would be nice to be able to download something through the client as now you can only play, but i would like to be albe to download as you can do with subsonic over http
One last thing is that subsonic is not working when opened inside iframe and i always with every release have to change in few places in jsp files "top." to the "parent." so it could work in <iframe>, if you could implement it in your standard release i would be more than greatful especially it does not change anything when subsonic is used normally without iframe
also is there anyway i could go back to standard player interface where t here is play/stop buttons because some times when video freezes because of some network problem, i could simply stop and play again to overcome this and now i have to refresh i' sure it is pretty simple to do if you only could explain me how to do it
cheers and keep the coding up ;)
gacopl
Postby Magica » Wed Sep 05, 2012 4:42 pm
Just installed newest mod to my primary server and everything seems to be working fine. In "2 minutes to midnight" theme left side scroll bar and alphabetical or number shortcurts are not working. Every other theme, that I tested, these functions are working ok.
When you have time, could you check this "2 minutes to midnight" theme. (My favorite theme)
But keep up the good work that you are doing!!
-m-
*Edit*
Same issue with Ripserver theme
Magica
Postby GJ51 » Wed Sep 05, 2012 5:17 pm
I've tried to decipher the theme thing a few times and came to the conclusion that there isn't a well defined structure that all themes use that make it easy to ensure that they are all compatible with changes to the program. I think this is becuse many of the themes have been contributed by users and may not all use the same program resources. It would really be nice if all themes were standardized and each element of a theme was easy for a user to customize.
I think maybe this is something that Sindre should look at.
I'm looking forward to the Android app. You're doing a great job and I'll make another donation when the app is released.
Postby MadEvil » Wed Sep 05, 2012 6:58 pm
gacopl wrote:Man you're doing tremendous job 20E (20 is really a lot in my country so imagine my gratefulness :) ) is going out for you, as it comes to android client there were few things that always pissed me in the original:
Hi, at first many thanks for donation, It's always nice to get recognition for this work!
I hope i can do some things for you:
*) Android Icon Sets, do you have any suggestions how it should look like?
*) do you have any notes about what you have changed for iframe modifications?
*) which standard player did you mean for video playback freezes, what should be changed?
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Wed Sep 05, 2012 7:00 pm
Magica wrote:Just installed newest mod to my primary server and everything seems to be working fine. In "2 minutes to midnight" theme left side scroll bar and alphabetical or number shortcurts are not working. Every other theme, that I tested, these functions are working ok.
i will check this!
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Wed Sep 05, 2012 7:05 pm
GJ51 wrote:I've tried to decipher the theme thing a few times and came to the conclusion that there isn't a well defined structure that all themes use that make it easy to ensure that they are all compatible with changes to the program. I think this is becuse many of the themes have been contributed by users and may not all use the same program resources. It would really be nice if all themes were standardized and each element of a theme was easy for a user to customize.
Well, there is a good structure for themes, but as you said allmost themes are user contributed. so everyone used the CSS stylesheet different :?
I'll try some repair.
best regards
Madsonic Developer
MadEvil
Return to Madsonic
