Madsonic - Mashup Mod (old Support Thread)
Re: Final: Madsonic Mashup Mod 4.7
Postby j3tblk » Tue Sep 25, 2012 10:11 am
GJ51 wrote:Yeah, I see it now. there is a bit of lag. I can see if you have a large number of starred items then the lag time might become very noticeable. I'll work on adding more stars to see how it behaves.
I also think that for some reason, selecting "Starred" from the home screen bar (just to the right of "Random") seems to respond more quickly that clicking the icon at the top.
Mine did this in the standard version until I went to 4.7 proper. I'm surprised to see 3125SE STILL the Beta 3 under the hood.
[9/25/12 5:04:06 AM CDT] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta3
j3tblk
Postby MadEvil » Tue Sep 25, 2012 1:30 pm
hakko wrote:
GJ51 wrote:I'll work on adding more stars to see how it behaves.
It sounds like you should rather run a query analyzer and see how the database executes the "starred" sql question, though? I'd guess it's doing a full table scan or something.
Thanks for the hint hakko,
dig into and replaced some query with more optimized readings, should work now really better!
best regards
Madsonic Developer
MadEvil
Postby tycoonbob » Tue Sep 25, 2012 1:40 pm
I love your Mashup Mod, and was using your 4.6 version and tried most builds through the 4.7 beta. All has been great, but I am having two little quirks that are annoying.
First, is streaming FLAC files. This problem happens over LAN or WAN, so it's not a bandwidth issue, but if I click a FLAC file, it won't start playing automatically. I have to skip the track ahead a few seconds, and then it will start playing. Once that track is done and it goes to the next, it doesn't start playing automatically either.
Second, if I sign in and check the box to keep me signed in, and then close my browser and go back into it later that day, I will have to log out and back in before anything will play. Before logging back out and back in, I would click to add a track, but it just wouldn't add.
Neither of these have caused any logs out of the ordinary, and I was hoping that it would end up being fixed in the final build, but it's not. I love your mods, but these bugs are enough that I can't use mashup mod. Thoughts?
Also, I have been using MadSonic too...and it works pretty good. I have also been using DSub, which is another forked Android app, so I am following both. I am hoping to see native video streaming in the app, instead of opening a browser...since Jelly Bean (Android 4.1) officially does NOT support flash, meaning I cannot stream videos from the app. I think a HTML5 player in MadSonic would be awesome, and I'm sure you could easily sell that for a couple bucks. It's a shame that I have to run SubSonic, plex, and TVMobili to have all my content available at all times, and if you could do a HTML5 player in the app...yeah, that would rock.
EDIT: Guess I should add that my SubSonic runs on a Server 2008 R2 VM, with 6 logical cores and 2-4GB of RAM. Resource-wise, I have never had an issue transcoding 1080p DTS MKVs in a browser, so I am sure I have enough power to transcode a FLAC file.
Thanks again MadEvil, great product except for my few quirks.
tycoonbob
Postby MadEvil » Tue Sep 25, 2012 1:41 pm
MoBO wrote:Hello !
I do have a simple question related to the version of Java needed.
On my NAS (Synology 1511+), I cannot install Java 7 so I'm still using v6.
According the first page (Build with: JDK 1.7.07/JDK 1.6.32/JDK 1.6.24), I would like to have a confirmation this package work correctly with v1.6.32/24.
Do anybody can confirm this ?
Thanks in advance
This mod is default compiled with java SDK 1.7_07, if you can't install it.
I made a Build revert and compiled the lastest version with Java SDK 1.6_35,
now this version should work with your Java 1.6/NAS installation -> Build 3130SE.
Best regards
Madsonic Developer
MadEvil
Postby jonnymnemo » Tue Sep 25, 2012 1:55 pm
MadEvil wrote:
jonnymnemo wrote:
MadEvil wrote:
TYI: Madsonic Mashup Mod works only with self hosted domain, the redirecting service from *.subsonic.org isn't working! (Work as Design)
Hi, and thank you very much for your work !
I don't understand the expression "work as design". ^^
Do you intend to make a .subsonic.org compatible version of your mod in the future, like you did with the 4.6 ?
Is there a working trick to use a subsonic.org server ?
Thanks for your answer !
GJ51 wrote:Actually, the redirect service will work if you do a few extra steps. I switched to the WAR version a while back once Bushman4 convinced me I wasn't too old to learn new tricks.
If you install Subsonic using the standard release and register the server.subsonic.org address, then change over to your modded setup and use the same port it'll work. I did that a few months ago when I started using the Mashup mod and never noticed that it was an issue.
Gary found this workaround! Maybe this can help.
best regards
Thanks for the tip ! :)
Actually, this workaround seems to be linked to the subsonic.properties file, which contains your xxxx.subsonic.org server informations (licence key, email adress, date of activation...). When you install the original subsonic, and then the madsonic one, this file is keeped. :P
jonnymnemo
Postby j3tblk » Tue Sep 25, 2012 1:55 pm
So where does one find "Build 3130SE" or 3130? Its not on the link on the first page....(am I too early?)
j3tblk
Postby MadEvil » Tue Sep 25, 2012 1:58 pm
j3tblk wrote:Mine did this in the standard version until I went to 4.7 proper. I'm surprised to see 3125SE STILL the Beta 3 under the hood.
This came from the default interface, there is no 4.8 beta1 tag out. so if sindre tag one new beta, there you can see this.
best regards
Madsonic Developer
MadEvil
j3tblk wrote:So where does one find "Build 3130SE" or 3130? Its not on the link on the first page....(am I too early?)
... uploading @ the moment :wink:
Madsonic Developer
MadEvil
Postby GJ51 » Tue Sep 25, 2012 2:18 pm
tycoonbob wrote:I love your Mashup Mod, and was using your 4.6 version and tried most builds through the 4.7 beta. All has been great, but I am having two little quirks that are annoying.
Getting Flac files to run properly is always a bit of a challenge in any version or variant of Subsonic, especially vbr files that have unexpected settings. I get the best results by setting up a seperate transcode definition for Flac files and using the ffmpeg file extravted from version 4.4 of Subsonic. I've renamed it "Audioffmpeg" so that you can call it only for use with Flac files. I suppose you could also call it Flacffmpeg if you want so that you know what it's doing.
You can download it from my Skydrive if you'd like to try it to see if it helps:
https://skydrive.live.com/redir?resid=A ... 0A32A0!233
Download and place the file in the transcode subdirectory.
Remove flac from the "mp3 audio" Convert from string
Create a new entry unde Add Transcoding
Flac > mp3 | flac | mp3 | Audioffmpeg -i %s -ab %bk -v 0 -f mp3 -
You'll then be using this version of ffmpeg to handle the flac transcodings. It has worked for me in the past for some difficult files. If you still have problems, I'd suggest doing some searches for "Stozher transcodings" - he had some custom transcodings for flac files that worked for many users.
EDIT: Here's the link to Stozher's thread: viewtopic.php?f=6&t=5121
HTH
Postby j3tblk » Tue Sep 25, 2012 2:31 pm
Awesome! Hoping this fixes my minor issues...thinking it is time to donate.
Just to be clear SE...is just for users that need Java 1.6 - correct?
j3tblk
Postby GJ51 » Tue Sep 25, 2012 2:34 pm
I just did the 313SE upgrade = works dandy - starred pops up quick!
I run on Java 1.7.05 without any issues. There were some 4.7 beta releases that had issues with Java 1.7 but I don't think any variant of Subsonic had any trouble related to running on Java 6.
Postby GJ51 » Tue Sep 25, 2012 2:56 pm
Aktarus wrote:Hello,
First, THANK YOU for your good work with this mod !!!
i only have one question ... Where I can see the SIMILAR ARTISTS feature ??
When a song is played, is it possible to see similar artists ??
MERCI :)
If you're looking for a similar artists feature, you should look at Music Cabinet - a different Mod program that has some different features you might find attractive.
viewtopic.php?f=8&t=9504
Postby GJ51 » Tue Sep 25, 2012 3:06 pm
There is still a bug that has been around a long time that has never been fixed that is way overdue as it affects the Radio function and any random generated playlist that has a duplicate in the playlist.
When any playlist has the same track entered twice in different locations in the list it creates a loop that causes the playback to loop back to the first entered instance, thus truncating the rest of the playlist. I don't know if there's an easy fix for this one, but it's been a part of Subsonic since the beginning.
Postby tycoonbob » Tue Sep 25, 2012 4:03 pm
HTH
Nice. Fixed my FLAC problems, so far at least. I'm in the process of redoing all of my audio, but the two FLAC albums that I specifically had issues with are working great now. Thanks for that.
Now to find a solution for my second issue.
tycoonbob
Postby MadEvil » Tue Sep 25, 2012 4:31 pm
MERCI :)
as default if you are online you can use this query to find other similar Artists viewtopic.php?f=8&t=5836
you have 2 options for similar Artists (in right frame or from Top frame)
if you want it to view in the right frame, there are 2 user settings to enable/disable
if you disable this 2 options you get the link in top frame -> Social
Madsonic Developer
MadEvil
Return to Madsonic
