Madsonic - Mashup Mod (old Support Thread)
Re: Release: Subsonic Mashup Mod B2625+
Postby MadEvil » Thu May 10, 2012 12:34 pm
SerpensAlatus wrote:Well,
i guess, i do something wrong.
I still cant enter the subsonic URL. ok, i can. But it does not work.
Any suggestions?
Regards
for own Domain Sharing use the correct Version
Own Sharing:
correct example: http://157.177.126.17:8080 or http://mysubsonicserver.com
false example: http://localhost or http://192.168.0.1
Default Sharing:
using the default Subsonic Subdomain USERNAME.subsonic.org --> http://www.subsonic.org/pages/getting-started.jsp
best regards
Madsonic Developer
MadEvil
Postby SerpensAlatus » Thu May 10, 2012 1:31 pm
MadEvil wrote:
Default Sharing:
best regards
Ty! Did this before, but the desired domain-name does not work. :(
Regards
SerpensAlatus
Postby MadEvil » Thu May 10, 2012 1:48 pm
MadEvil wrote:
Default Sharing:
best regards
Regards
you used the wrong method with the wrong technique! :wink:
If you want to use your subsonic registration license and subdomain registration you MUST use the Default Sharing Version!
In the Own Domain Sharing Version the function to use the xxx.subsonic.org domain forwarding is disabled!
so use the correct Version for you need!
Default Subsonic Sharing --> http://ul.to/file/gn1d5vzg/20120509_sub ... -setup.zip
Own Domain Sharing --> http://ul.to/file/49cg942b/20120509_sub ... -setup.zip
Best regards
Madsonic Developer
MadEvil
Postby SerpensAlatus » Thu May 10, 2012 3:10 pm
So its not enough only to change the war-file?
Well. Didnt know that.
SerpensAlatus
Postby MadEvil » Thu May 10, 2012 4:17 pm
SerpensAlatus wrote:So its not enough only to change the war-file?
its my fault, i used for both version the same Build Number, so you must manually delete your jetty cache if you only replace the subsonic.war file
if you want to change between the versions you better uninstall the whole installation or ...
1. Stop Server
2. clear your Internet browsers cache AND cookies
3. clear (delete) subsonics internal cache (the jetty cache is at subsonic/jetty/<num>/jsp/org/apache/jsp/*)
4. replace this 2 files in you subsonic folder
*) subsonic.war
*) subsonic-booter-jar-with-dependencies.jar
5. restart server
6. restart browser
i hope this helps ... :)
Default Network Sharing looks different ...
Madsonic Developer
MadEvil
Postby jared68 » Mon May 14, 2012 5:46 pm
Question about the More section and where you are able to generate random playlists.
i updated to v 2625+ and have noticed that this look
Has there some change been made, I don't remember it being like this previously.
jared68
Postby tycoonbob » Mon May 14, 2012 8:18 pm
After replacing the WAR and other files, restarted my server and it is working great. The only thing that I can complain about, is that my stats are not showing up on the top left (album, artists, songs, size, etc). Now is this related to indexing, and does SS have to rescan before those stats appear again? I have a scan in progress, but having over a TB of data, I assume it will take a little while...but while it's in progress, still no stats. Thoughts?
EDIT: Yeah, that was the issue. I was just not patient enough. This mod is awesome! (will leave my comment in case any others have the same issue)
tycoonbob
Postby TheWarden » Fri May 18, 2012 3:17 pm
A really nice collection of modifications - thanks for the hard work. I have a couple of comments (mostly personal preferences).
It seems like you've increased the width of the left hand folder list frame? I personally prefer the original width. Also the "search" box seems to be positioned a little awkwardly - should it be indented? Am I the only one who thinks that you should only show similar artists that are in your collection? Or of the 3 artists shown prefer showing ones in your collection? Can you add the captions subtitle plugin to JWPlayer (viewtopic.php?t=5300)? Saves me having to edit the war file each time. I like the ability to change rows/columns but it would be great if it saved the user preference next time you logged in. Is the "social" page really all that useful? It just replicates info already visible in the right hand side. The random filelist generator graphic doesn't really fit very well with the rest of Subsonic's style. Can it change with theme? The same for the pop out upload window? I think I prefer the "Log out <user>" as text rather than a power button icon - it's clearer. I'd also prefer to see it placed top right as this is the usual place for log out buttons on most websites.
Other than that it's a great collection of mods and saves me a lot of hackery!
TheWarden
Postby tzortst » Tue May 22, 2012 1:15 am
Any plans to add genres? and genre search?
tzortst
Postby MadEvil » Thu May 24, 2012 2:19 am
tzortst wrote:Any plans to add genres? and genre search?
yes, many things are in Planing ..
*) Advanced per User & Overall Statistics
*) Mixmode Folderstructure/ID3-Tags
*) better AlbumSet Detection
*) Genre Browser/Player
*) Artist Radio
*) Search
*) more
meanwhile you can test the new 4.7 Build @ First Post
Best Regards
Madsonic Developer
MadEvil
Re: Technical Preview: Subsonic Mashup Mod 4.7 B2992+
Postby tycoonbob » Thu May 24, 2012 5:51 pm
Testing the 4.7 build now. I am so excited; been waiting what seems forever!
EDIT: Not working for me.
I downloaded the setup, and it installed. Configured to use HTTP, set my memory to 512 like always...restarted the service and getting a 404 when trying to browse to.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
To clarify, this was a clean install after uninstall my stock 4.7b1 install, and deleting the subsonic folder on the root of my C:. After this failed, I uninstalled build 2992, reinstalled the stock 4.7b1, and installed 2992 overtop...and it's working again.
tycoonbob
Postby MadEvil » Thu May 24, 2012 7:32 pm
tycoonbob wrote:Testing the 4.7 build now. I am so excited; been waiting what seems forever!
HTTP ERROR: 404
NOT_FOUND
look at this http://subsonic.svn.sourceforge.net/vie ... ision=2986
i merged this changes with my build 2992.
maybe wrong port default ist now 4040?
do you found error in the subsonic.log file?
do you clean the whole subsonic folder before installation (incl. db & jetty folder and also the subsonic.properties)?
best regards
Madsonic Developer
MadEvil
Re: Technical Preview: Subsonic Mashup Mod 4.7 B3000+
Postby MadEvil » Thu May 24, 2012 8:13 pm
Hidden Feature
the logic to detect Album or Artist in the 4.7 MashupMod build =< B2990+
Albums can be rated and starred, Artist Folder only by starred
this also relvant vor the search function Resust Artist or Album.
*) all Folder are album folder --> Album
*) Folder have no Audio files --> Folder --> Artist
*) Folder with subfolders and audiofiles within --> AlbumSet --> Album
*) Foldername contains (CD%,disk%,part%,teil%) --> AlbumSet Name --> % - Disk%01
*) Folder contains any "artist" file example artist.png -> Folder --> Artist (to get the Artist View)
also included --> viewtopic.php?f=8&t=9453
Madsonic Developer
MadEvil
Postby MadEvil » Fri May 25, 2012 11:37 am
New Build
Changelog 4.7
Build 3000
UPDATE: downgrade to DWR 3.0 Build RC1 (Bugs with RC2 & RC3)
UPDATE: Tag as beta2
FIXED: Code Cleanup
Link --> viewtopic.php?f=8&t=9187
8) Best
Madsonic Developer
MadEvil
Postby tycoonbob » Fri May 25, 2012 11:50 am
HTTP ERROR: 404
NOT_FOUND
best regards
I verified it was the correct port, as I changed the port to what I am allowing through my firewall. I even clicked the link in the SubSonic client to confirm I was typing it right. I also cleaned up after my 4.7b1 uninstall, by deleting everything (including the db and jetty folders, and subsonic.prop). It just couldn't find it. Anyway, I am about to do another cleanup...and install build 3000, before heading off to work. I will let you know how it goes once I get to play with it a little bit!
EDIT: Already ran into an issue. :(
Every time a page loads, I get a popup warning which says:
Failed to find parameter: httpSessionId
Once I hit okay, it may popup up to another 4 times, but it seems the page is loading fine. This happens with the latest version of Chrome for me, clean install.
tycoonbob
Return to Madsonic
