Madsonic - Mashup Mod (old Support Thread)
Re: Technical Preview: Subsonic Mashup Mod 4.7
Postby MediocreFred » Thu Jun 07, 2012 1:51 pm
The feature list of this mod looks awesome and I am really keen on trying it out.
The only thing that is holding me back is not knowing if this will impact the various players that folks are using (such as, iSub, the android subsonic player, Periscope and other such players/apps for the IPhone and Windows that are listed here - http://www.subsonic.org/pages/apps.jsp.
I have a few friends who have "paid" versions of these apps and use them extensively to connect to my Subsonic server. While I crave this mod, I don't want to cause their apps to stop working.
MediocreFred.
MediocreFred
Postby gigon » Thu Jun 07, 2012 2:13 pm
I am currently listening via iSub to my mashup-modded Subsonic, everything works fine. ;)
Subsonic Package for Synology DiskStations http://eg-blog.de
gigon
AW: Technical Preview: Subsonic Mashup Mod 4.7
Postby MadEvil » Thu Jun 07, 2012 2:25 pm
Hi, nothing is changed in the Interfaces, so all my Client Appps work without modifications.
But you cant downgrade the database to an old subsonic Version example 4.6
Best regards
Madsonic Developer
MadEvil
Postby ananda96 » Fri Jun 08, 2012 1:36 am
First wanna say thank you for this nice featured mod,
as recommended i installed it from scratch and it worked fine.
using last version 3016 i've got a lot of JAVA Errors...
Then i did again a fresh install and reconfigured everything, now i got on particular Folders or when click to parent Folders (Genres in my case) JAVA Errors.
Exception    java.lang.IllegalArgumentException
Message    Comparison method violates its general contract!
Java version    Oracle Corporation 1.7.0_04
Operating system    Windows 7 6.1
Server    jetty-6.1.x
Memory    Used 144 of 246 MB
Is it really necessary to downgrade JAVA to old JAva Version?
ananda96
Postby MadEvil » Fri Jun 08, 2012 8:54 am
Hi, Yes Java 1.7 is general a Problem with subsonic, i hope Sindre is working on that.
Link -> viewtopic.php?t=9202
Best regards
Madsonic Developer
MadEvil
Postby ananda96 » Fri Jun 08, 2012 9:14 am
thanks for response...
i would like to suggest a feature...
save configuration in an *.ini file or similiar (folders/settings etc.)
add entire Hard Drive instead of Folders? (that's what i'm really missing)
ananda96
Postby Drefsab » Sat Jun 09, 2012 8:51 am
One feature I would love to see but there are no mods that I can find, is the ability to delete media from the library (perhaps this could be admin only). This would be useful for example to me when watching tv episodes, I watch what I want then have to make a note of what I've watched and then ftp into my server and manually delete the files. It would be a lot easier to have an option to delete it in the subsonic UI.
Drefsab
Postby tycoonbob » Mon Jun 11, 2012 3:09 pm
just installed build 3016, and so far things are great. Scanned about 1.5TB of media in less than 10 minutes, and I love the DB button (nice and convenience).
tycoonbob
Postby maos01 » Mon Jun 11, 2012 7:33 pm
Subsonic 4.6 with Mashup Mod 2625+
Unfortunately comment function on artist or album function does not work for me. Form is not shown.
Can somebody give a hint how to resolve this, please?
Thanks.
maos01
Postby tycoonbob » Thu Jun 14, 2012 12:16 am
So I am having two issues, which are making this latest build unusable for me. Everytime I load up SubSonic in Chrome (not sure about other browsers), I get this popup error:
Cannot call method 'addEventListener' of undefined
I have to log out, and then log back in before ANYTHING will play.
Secondly, MP3s will not play. Well, some MP3s will...but I'm thinking it has sometime to do with downcoding MP3s maybe? I dunno. Transcoding MP3 to MP3 or streaming MP3 natively makes no difference, and the strange thing is...my log files on my server are not updating.
I want to close with a question...do your mashup mods eliminate viewing logs from the SubSonic web interface? I can't seem to find them.
tycoonbob
Postby jdubso » Fri Jun 15, 2012 3:46 pm
I love this mod, I have no errors and everything seems to work fine. The following are issues that I have encountered:
    +When i add cover art for an album through the image search it says it downloaded fine, and the file shows up as cover.jpg but it won't show up in the folder in subsonic, even with a new folder scan. If you click to enlarge it shows, just not in the normal view. <-- if you clear the browser cache they show up
    +The sort by folder structure isn't working.
    +When the chat window is on the right below the users the text does not wrap and bleeds off the screen.
    +There is no button/link at top to access about page with subsonic log <-- figured this out, click subsonic logo on top left
Thank you again. I love this look.
jdubso
Postby paradym3 » Fri Jun 15, 2012 8:28 pm
Great work with this! Thanks to everyone who contributed!
For some reason my Similar Artists are not showing. This is supposed to be enabled by default correct? No additional config is needed? It does not display in IE8, Chrome, Firefox.
Specs:
Windows Server 2008 R2 SP1
IIS with ARR routing to Apache Tomcat
Thank you,
Craig
paradym3
Postby MadEvil » Thu Jun 21, 2012 11:01 pm
ananda96 wrote:First wanna say thank you for this nice featured mod,
Server    jetty-6.1.x
Hi, now this should work with the new Build 3020.
Best regards
Madsonic Developer
MadEvil
Postby MadEvil » Thu Jun 21, 2012 11:04 pm
Drefsab wrote:One feature I would love to see but there are no mods that I can find, is the ability to delete media from the library (perhaps this could be admin only). This would be useful for example to me when watching tv episodes, I watch what I want then have to make a note of what I've watched and then ftp into my server and manually delete the files. It would be a lot easier to have an option to delete it in the subsonic UI.
hi, i investigate this feature!
Best regards
Madsonic Developer
MadEvil
Postby MadEvil » Thu Jun 21, 2012 11:06 pm
tycoonbob wrote:So I am having two issues, which are making this latest build unusable for me. Everytime I load up SubSonic in Chrome (not sure about other browsers), I get this popup error:
Hi, i have bundled Mashmod with a newer ffmpeg, maybe this is a problem for transcoding.
Try it with the original from subsonic 4.6.
Best regards
Madsonic Developer
MadEvil
Return to Madsonic
