Navigation: MAIN | INFO | CHANGELOG | DOWNLOAD | ANNOUNCEMENTSCHANGELOG! FOR SERVER CHANGELOG SROLL DOWN !Changelog Android ClientBuild 4.0.8.150NEW: Feature: Add new Views: Starred Songs, Albums by Name, Albums by Artist
Build 4.0.7.143NEW: Update: Fixed host name can't be null
NEW: Update: Code-Cleanup
Build 4.0.6.140NEW: Update: Madsonic Skin
NEW: Update: Resize Thumbnails
Picture Gallary Madsonic Android Client Gallery Link **NEW**
Build 4.0.4.124NEW: Update: German Translation
Build 4.0.4.120NEW: Update: Tip-View
Changelog Server 4.8 BranchBuild 3360NEW: Feature: Icon Setting also for adminuser (configurable)
NEW: Update: new French Translation (User: lanzari)
NEW: Update: update German Translation
NEW: Update: update Norwegian Translation
NEW: Update: update Swedish Translation
NEW: Update: update Spanish Translation
NEW: Update: update Finnish Translation
NEW: Update: Upgrade to latest
ffmpeg version (Win/Linux)
NEW: Update: Upgrade to java installer version to 1.7_17
Build 3350NEW: Update: Typo on Fedora-install
Build 3348NEW: Feature: Last.FM Match
NEW: Update: Jquery/Jquery UI Fixes
Build 3340NEW: Update: Revert some Jquery Updates (Scroll-Fix)
Build 3338NEW: Update: Jquery/Jquery UI Fix
Build 3336NEW: Feature: Artist Hub Detail-view
NEW: Feature: Artist TopTag Radio
NEW: Feature: Moods Radio (if Audio Tag Support this)
NEW: Feature: Last.FM Sync Service for Artist Info & more
NEW: Feature: New Setting: howto show Shortcuts
NEW: Feature: Testfiles for HTML5 Player
NEW: Feature: REST: startRescan, scanstatus
NEW: Theme: Updates Themes
NEW: Update:
http://sourceforge.net/p/subsonic/code/3336/NEW: Update:
http://sourceforge.net/p/subsonic/code/3335/NEW: Update:
http://sourceforge.net/p/subsonic/code/3334/NEW: Update:
http://sourceforge.net/p/subsonic/code/3317/
NEW REST APIs:
startRescan,
scanstatusEXAMPLE:
- Code: Select all
http://localhost:88/rest/startRescan.view?u=admin&p=admin&v=1.9.0&c=WebScript
http://localhost/rest/scanstatus.view?u=admin&p=admin&v=1.9.0&c=WebScript
RESULT:
- Code: Select all
<subsonic-response xmlns="http://subsonic.org/restapi" status="ok" version="1.9.0">
<Scan>
<Status started="false"></Status>
</Scan>
</subsonic-response>
- Code: Select all
<Scan>
<Status started="true" count="1052"></Status>
</Scan>
Build 3320NEW: Feature: Changed TranscodingService (Native Support for Clients)
NEW: Feature: Default Video Bitrate via Security Groups
NEW: Feature: mark new added Album with New-Icon
NEW: Feature: Add Playlist instead of only Play
NEW: Feature: Updated New Version avilable
NEW: Feature: REST API Update to Rescan Mediafolders
NEW: Theme: SigelSonic Update 1.0
Build 3312NEW: Theme: Big Updates to many Themes
NEW: Theme: Reskin Theme "Barents Sea" for Madsonic
NEW: Theme: SigelSonic Updates
NEW: Update: Update JQuery UI template
NEW: Update: Make Themes more Skinable
Build 3310NEW: Feature: Madsonic now supports Installation on Tomcat 6.0.35/Tomcat 7.0.34
NEW: Feature: create named Playlist from main.view
NEW: Update: Update Podcast REST Api
NEW: Theme: SigelSonic Update 0.5
NEW: Update: ThreeJS v0.54
Build 3306NEW: Feature: Enable/Disable Default ArtistCover
NEW: Update: SigelSonic Theme Updates
Build 3304NEW: Feature: new Usersetting Audiohide Chat-Panel
NEW: Update: Chat-Panel Text wrap around Fix
NEW: Update: SigelSonic Theme Custom Accordion
NEW: Update: many Theme/Css Fixes
NEW: Update: REST API 1.9.0
NEW: Update: HLSController Update Fix
NEW: Update:
MiniSub to 2.3.8
https://github.com/tsquillario/MiniSubBuild 3292NEW: Theme:
Madsonic Corporate NEW: Update: Fixed missing JQuery UI template
Build 3290NEW: Feature:
Playlist Easy Share (for example Greeting Cards)
NEW: Update: Fixed
duplicated Entries in PlayQueue Bug (Radio.view)
Build 3288SENEW: Special Build: Reverted to Java 1.6 compiled version
Build 3288NEW: Feature:
Folderselection Sort is now configurable (GeneralSettings.view)
NEW: Feature: Cleanup
File LoggingNEW: Update: Fixed
Access Default Rights (MediaFolder or Group) Reset Access Rights no more needed!
NEW: Update: Fixed
Scanning Build 3280NEW: Feature: Madsonic
Artist HubNEW: Feature: Custom
Arrcordion in Left Frame
NEW: Feature:
better Sorting (Year, Foldernames, Filenames, REST, ..)
NEW: Feature: Set
Default Icons for Top Frame
NEW: Feature: Artitsts stretched over several mediaFolder, now correctly sorted
NEW: Feature:
Folderselection is now sorted
NEW: Feature: nicer
Logon View
NEW: Feature:
Save all Title to Playlist directly from Dropdown
NEW: Feature:
Redesign Left Frame, (show/hide) Statistics & Shortcuts
[b]NEW: Update: Fixed Access Right if new MediaFolder is added
NEW: Update: Fixed Scanning Error
NEW: Update: Fixed broken REST Errors
NEW: Update: some Theme Updates
NEW: Update: Update Jquery 1.8.3
NEW: Update: Update Jquery UI 1.9.2
NEW: Update:
MiniSub to 2.3.4
https://github.com/tsquillario/MiniSubNEW: Update: Upgrade to latest
Build 3220NEW: Update: Fixed Jaudiotagger Parsing Error
NEW: Update: Fixed MediaFileScanner Error
Build 3218NEW: Update: Fixed MetaDataParser Bug if Year is in format 2012-05-07
NEW: Update: Fixed MediaFileScanner Bug if Artist have no Tags
NEW: Update: Podcast Downloader increased to 5 downloads simultaneously
NEW: Update: trimmed REST Filter Errors on broken Streams
NEW: Update: add Tip & Alphabetically View to Listtype (personalSettings.view)
NEW: Update: Jaudiotagger updated
Build 3216NEW: Feature: Use Subsonic Premium Redirection Services or Share with your own Domain (optional in GeneralSettings.view)
NEW: Feature: Sort Files by Filenames (default is alphabetically) (optional in GeneralSettings.view)
NEW: Feature: Set Default Leftframe Size (optional in GeneralSettings.view)
NEW: Feature: Set Default PlayQueueframe Size (optional in GeneralSettings.view)
NEW: Update: some Updates to Sonic-Theme
Build 3210SENEW: Special Build: Reverted to Java 1.6 compiled version
Build 3210NEW: Feature: Advanced Media Library Statistics. (correct artist/album Counts)
viewtopic.php?f=15&t=10445&p=48495#p48495NEW: Update: Sort folder by foldernames works also on Artist folder
NEW: Update: Fix TYPO on cleanupSettings.view
NEW: Update: directwebremoting 3.0.0-rc3-SNAPSHOT
Build 3206NEW: Feature: Sort albums by foldernames (optional in GeneralSettings.view)
NEW: Update: CleanupSettings.view
Build 3204NEW: Update: Fixed REST API Calls - Access Control
NEW: Update: Fixed Random-Search Function - Access Control
NEW: Update: Fixed Radio Random title Code - Access Control
Build 3200NEW: Feature: Madsonic Media-Folder
Access Control viewtopic.php?f=15&t=10491NEW: Feature: Support for
Subtitle on Videos (Example: <videofile>.srt)
viewtopic.php?f=15&t=10460#p47498NEW: Feature: Import from each folder a
comment.txt into Album-Comment field
viewtopic.php?f=15&t=10573NEW: Feature: New Cleanup-Tools Page (Settings.view)
NEW: Update:
MiniSub to 2.2.7
ffmpeg version 31.10.2012 (Win/Linux)
NEW: Update: Upgrade to latest java libraries (DWR, common-io)
NEW: Update: standalone Transcoding Pack -> (
http://uploaded.net/f/sctmqc)
Changelog 4.7 BranchBuild 3158NEW: Update: MiniSub to 2.1.7
https://github.com/tsquillario/MiniSubNEW: Update: enabled Step3 for transcoding
NEW: Update: Bugfix Flac/m4a transcoding
NEW: Update: for better split transcoding on linux/windows to:
Audioffmpeg ->
audio,
ffmpeg ->
video NEW: Update: standalone Transcoding Pack -> (
NEW: Update: Update Rest API for Tips
Build 3155NEW: Update: Update transcoding m4a/flac Transcoding Packs -> (
Build 3154NEW: Update: Filetaging: to auto overide the mediatype use:
- madsonic_multi.tag
- madsonic_artist.tag
- madsonic_album.tag
- madsonic_set.tag
- madsonic_dir.tag
NEW: Feature: Exclude files and folders listed in a
madsonic_exclude.txt file (put in each line a folder/filename to exclude)
NEW: Feature: Search in left.view is pinned to top
NEW: Feature: in home.view new random Tip-View from Top Recommended Albums
NEW: Feature: grouped all Statistics together in status.view
NEW: Feature: now as Default the Playlist Overflow is hidden in left.view
NEW: Feature: in General-Settings the Playlist Path Setting are back (for later Autoexport Feature)
NEW: Update: Upgrade to latest ffmpeg version 10.10.2012 (Win/Linux)
NEW: Update: new transcoding settings for FLAC & SubWiji
NEW: Update: db.view link to new table transcoding2, player_transcoding2
FIX: jump to anchor is overlapped in left.view
FIX: Update: resolved many Theme Issues[/color]
Build 3146
NEW: Feature: in edittags.view now you can edit the AlbumArtist value (Various Artists)
NEW: Feature: in left.view new Options 'Show All', 'Hide All', 'Show Some' for Playlists
NEW: Feature: User-Role 'Search' to cut down the interface for guests
NEW: Feature: User-setting 'CustomScrollbar' to enable/disable for each user
NEW: Theme: 'Madsonic Kids' to test some new CustomScrollbar Styles for -webkit Browser (Chrome)
NEW: Update: db.view - Better Layout
NEW: Update: log.view expand to 500 lines
FIX: Update: playQueue - Scrollbar Fix
FIX: Update: Append Starred Items to Playlist Fix
FIX: Update: db version Upgrade
Build 3132SE
Build 3132
NEW: Feature: Save Starred Items to Playlists
FIX: Update Theme issues
NEW: Update booter.jar
Build 3130SE
Build 3130
NEW: Feature: Use 4 different Index Styles for each Music folder Content viewtopic.php?f=3&t=10229#p46236
NEW: Update: common.io 2.4
NEW: Update: junit 4.8.2
FIX: Update Starred Queries for speedup
FIX: Update some Theme issues
Build 3124
NEW: Update Scan Progress visible in Top Frame
NEW: Update: Springframework 2.5.6.SEC03
NEW: Update: acegi-security 1.0.7
NEW: Update: common.langs 2.5
NEW: Update: HSQLDB 1.8.0.10
NEW: Update: HTTPClient 4.2.1
NEW: Split About & Log View
NEW: Code Cleanup
Build 3120
NEW: Optimize Database Upgrade from Subsonic 4.6, 4.7, 4.7 Betas (Now you can migrate your old DB) thanks to hakko
NEW: Mashuped Theme SubStandard, Cool and Clean
NEW: Update Carousel (Resize), Random View
NEW: Update some little Theme issues
Build 3112
NEW: Merged uncommitted Final Changes
NEW: *) Comment delete Play-count Fix
NEW: *) Playlist-import Fix
NEW: *) Scrobble Fix
Build 3110
NEW: Merge to latest SVN Branch http://subsonic.svn.sourceforge.net/vie ... ision=3091
FIX: Update JSP to work in IFrame
NEW: Revert to older Linux ffmpeg (works best with flac, m4a, ...)
NEW: Revert to older Windows ffmpeg (works best with flac, m4a, ...)
Build 3106
FIX: Update 'Back in Black' Theme issues
NEW: Include MiniSub 2.0.6
FIX: fixed REST API for MiniSub
NEW: fixed Similar Artists CSS Styles
FIX: finally fixed jumping & bouncing Scrollbar
FIX: Prevent Player Cache Issues
NEW: Update Linux ffmpeg - 20120904-static.32bit
NEW: Update Windows ffmpeg - 20120903-git-5d55830-win32-static
Build 3102
NEW: Tweaked Search-function (Now you can use Wildcard at beginning, Example: *40 -> UB40, Apollo 440)
FIX: fixed broken REST Video-page
FIX: fixed Similar Artists View!
NEW: JQuery 1.8.1 Update
NEW: JQuery UI 1.8.23 Update
FIX: hopefully fixed jumping & bouncing Scrollbar
Build 3100
NEW: New Feature to set recommend Albums for Carousel
FIX: Bugfix broken Create Shares Buttons
NEW: Left Frame Refresh Link
NEW: wtv File Support
FIX: some GUI Fixes
Build 3098
NEW: New Feature to enable/disable Album Year in main.view (General Settings)
NEW: New Feature to enable resizing on LeftFrame (Personal Settings)
NEW: Fix Bug autowidth in LeftFrame (Browser-Zoom)
NEW: Fix Genre serialization on Radio Tags (Radio)
NEW: Fix broken Comment Function (Main)
NEW: Update MediaType detection (File Tags)
NEW: Update MediaType Selection enabled only for Coverart/Tag Admins (Secruity)
Build 3092
NEW: Update to latest ffmpeg build
NEW: New Feature to enable resizing on PlayQueue Frame
NEW: Fix IE Bug to prevent display Custom Scroller
NEW: Fix Theme "Back on Black" Playericons
NEW: Fix Iconpath on Videoplayerpage if not root content is used
NEW: Disable GZIP Filter, prevent startup on Tomcat6
NEW: DB Link in Top only enabled for Admins
Backlog
NEW: Add Custom Scroller to: Home, Main, Starred and Radio View
NEW: Fix Custom Scroller (some Overlay Bugs)
NEW: Fix all Themes to work with Custom Scroller
NEW: Fix Custom Scroller (some Bugs with Firefox)
NEW: Fix Theme Selection don't work on linux
NEW: Update .deb and .rpm packages
NEW: Complete rework of Custom Scroller (works now better on scrolling, resizing, new Content)
NEW: Merge SVN Commits 3030-3083 (beta3) http://www.subsonic.org/pages/changelog.jsp
NEW: Update Jquery UI 1.8.22
NEW: some Mod Codecleanup
NEW: Better Layoutsupport for Android Tablets
NEW: Fixed slow "Top rated" http://subsonic.svn.sourceforge.net/vie ... ision=3030
NEW: Update to JWPlayer 5.10
NEW: Update to FFmpeg git-c17808c 32-bit Static (windows)
NEW: Update Windows Installer package with JRE 1.7
NEW: Theme split: Madsonic (dark), Madsonic (black)
NEW: Updated Slovenian translation http://subsonic.svn.sourceforge.net/vie ... ision=3022
NEW: Autoimport Playlists http://subsonic.svn.sourceforge.net/vie ... ision=3023
NEW: Fixed problem with content removing and re-adding http://subsonic.svn.sourceforge.net/vie ... ision=3024
NEW: Clean-up database function http://subsonic.svn.sourceforge.net/vie ... ision=3027
NEW: First Build with JDK 1.7.05
NEW: Update exe4j 4.4.5
NEW: Update Jquery 1.7.2
NEW: Update Jquery UI 1.8.21
NEW: Update JWPlayer 5.9.2268
NEW: Update Externalplayer (new Skin, Next & Previous Button are back)
NEW: Sinkable Scrollbars (Left & Playqueue Frame)
NEW: Bugfix Playqueue jumps to top on next Button
NEW: Optimize AlbumArtist Tag reading
NEW: temp. disable broken Similar Artist Function (come back soon)
UPDATE: Code Cleanup
UPDATE: Merge to latest SVN Branch
NEW: Advanced User History
NEW: Advanced Albumset Visualization
NEW: Advanced parse/truncate/order Year Tag from Folder structure
UPDATE: Statistics
FIXED: Scanservice/TruncateYear Error
UPDATE: to FFmpeg git-fce30d8 32-bit Static (24.05.2012)
UPDATE: Getting Started.html Link -> Port 4040
UPDATE: to JWPlayer 5.9 Build 2206
Changelog 4.6
Build 2625
FIXED: Code Cleanup
FIXED: broken Dependency to booter.jar
Backlog
NEW: Default/Own Domain Sharing
FIXED: fixed externalPlayer (disable Revolt-Plugin if first Playlistentry is a video)
FIXED: smilar Artist showed in Right Frame
FIXED: fixed Link Colour in Themes
FIXED: add "2 minutes to midnight" Theme
FIXED: Revolt Plugin is default off if playing/sharing Video (External Player)
FEATURE: Make browser blink when there is a new chat message (Right Frame)
FIXED: fixed the Slick Theme
FIXED: Default Theme Iconsize
FIXED: Windows & Linux compatiblity in UploadPath
FIXED: IE9 dont need compatiblity mode to view correct Coverart
FEATURE: You can set in GenerallSettings the default listType Value for new Users
NEW: nicer Star/Rating Icons
