The random albums not being able to click play all is a different issue from the one the other user was reporting. Someone just reported the issue you are having the other day and I will look at it. I guess I never try to play all random albums. I usually use the shuffle all function from the main screen or I go down to a random album and play a single album and both those work.
As for the second issue I haven't heard anyone else getting the set of extra options intermittently. Are you sure you are pressing the same shuffle icon on the same tab on all devices. For example pressing shuffle on the now playing tab won't bring up the menu it just shuffles the now playing list. Try pressing the shuffle icon on the first tab in Dsub to see if you only get the menu on some.
wg4ever wrote:Also, the previous app I was using (Audiogalaxy) was able to basically shuffle my entire collection indefinitely, loading more songs from my collection as needed. I notice DSub has you set how many songs you want loaded into the shuffle playlist. I drive on long road trips. Any chance of having an option of this kind of shuffle mode? Thanks!
wg4ever wrote:DSub has suddenly started crashing every time I use it. It locks up my smartphone and I have to shut it off and back on. I've only been using it for about a week. I am using it on a Samsung Galaxy Note II, using the Jellybean version of firmware. Is anyone else experiencing this issue?
