DSub for Android
Re: DSub for Android
Postby bry » Sun Sep 02, 2012 5:53 pm
How well does dsub play w navigation? On older android versions when I would be using gps subsonic audio would lower when a new navigation direction would occur. Any ideas? Ty
Edit- does anybody know if this works with zombie run by six to start?
Sent from my DROID RAZR using Tapatalk 2
bry
Postby daneren2005 » Tue Sep 04, 2012 3:07 am
bry wrote:How well does dsub play w navigation? On older android versions when I would be using gps subsonic audio would lower when a new navigation direction would occur. Any ideas? Ty
I really don't have a clue what you are asking in either of your questions.
Postby GJ51 » Tue Sep 04, 2012 3:23 am
I do. He's talking about the music volume automatically muting when the navigation instructions are given, I took a road trip recently using GPS Google maps for instructions while using Dsub. It was fine. I can't remember the details of whether it actually muted the music, but I was able to hear the driving instructions just fine. I guess if I didn't notice any problem it must be working fine.
HTH
Postby daneren2005 » Tue Sep 04, 2012 4:12 pm
Ah, then if that is what he is talking about then that is completely out of the app developers control. AFAIK the API is designed that way so that when apps try to play something they can mute the stuff in the background temporarily while it plays. And really I'm not sure why you wouldn't want that to happen since otherwise you can't hear the driving instructions that you are given.
Postby bry » Tue Sep 04, 2012 7:30 pm
Sorry for the confusion - thanks for the answer.
bry
Postby bry » Wed Sep 05, 2012 1:31 am
Just purchased. Will let you know thoughts. Ty
bry
Postby atka » Thu Sep 06, 2012 4:03 am
It still has the problem of not muting or ducking the music when the navigation is giving directions, at least in JB and ICS also had this bug with the subsonic app.
atka
Re: Re: DSub for Android
Postby bry » Thu Sep 06, 2012 4:33 pm
atka wrote:It still has the problem of not muting or ducking the music when the navigation is giving directions, at least in JB and ICS also had this bug with the subsonic app.
Anyway this could be fixed?
Also i can't resize the widget
bry
Postby daneren2005 » Fri Sep 07, 2012 10:22 pm
Hmm I thought it did that automatically but I'll take a look into it. And the widget should be fixed soon.
Postby EikelenboomJ » Sat Sep 08, 2012 6:19 am
Just downloaded the new version and saw the lockscreen widget. Many many thanx for that. Works like a charm.
EikelenboomJ
Postby bry » Sat Sep 08, 2012 10:24 pm
Thx for update. Update has however broken the app for me. Once i select a song or album to play i get a force close. I have removed and restarted the device.
bry
Postby daneren2005 » Sat Sep 08, 2012 10:47 pm
bry wrote:Thx for update. Update has however broken the app for me. Once i select a song or album to play i get a force close. I have removed and restarted the device.
Are you on Android 2.3 or 4.0?
Postby bry » Sat Sep 08, 2012 11:44 pm
4.0. Only fc in offline mode
bry
Postby daneren2005 » Sun Sep 09, 2012 4:28 am
Alright sorry about that. The update I just pushed should fix the issue. Apparently in offline mode getDuration is null for some reason and I wasn't doing an explicit check for it.
Postby bry » Sun Sep 09, 2012 12:50 pm
Thanks for the quick fix and the lock screen widget. Would it be possible to add the ability to save playlist files locally?
bry
Return to DSub for Android
