Play Store Beta
Re: Play Store Beta
Postby daneren2005 » Tue Mar 11, 2014 1:41 pm
I've added a new beta to the store. The main thing I would like feedback on is whether the ChromeCast fixes I put in work for everyone. There were also numerous other improvements, so be on the lookout for anything that seems broken.
Re: Play Store Beta
Postby daneren2005 » Sun Apr 27, 2014 10:41 pm
Added 4.6 Beta with some major UI changes with large album art and pull to refresh
Re: Play Store Beta
Postby wesssider » Mon Apr 28, 2014 12:08 am
Could the large art be configurable? It may grow on me but it now takes a lot longer to swipe through large lists. I'd be more willing if the Library had the same fast scroll as 'Now Playing' has.
wesssider
Re: Play Store Beta
Postby daneren2005 » Mon Apr 28, 2014 12:33 am
I'm probably not going to make it configurable. That would require a crap ton of duplicated code. What lists do you have that large that require a lot of swiping through? I can add it to the album lists like Recently Added pretty easily, but do you really have artists with that many albums to swipe through?
Re: Thumper -- A native OS X client for Subsonic
Postby jdubso » Mon Apr 28, 2014 1:51 am
Can you make the new large album art an option? Large album art or old fashioned list?
jdubso
Re: Play Store Beta
Postby djphillyp » Mon Apr 28, 2014 1:31 pm
hey
I notice on nexus 5 if you go a page with the new bigger album art that dsub crashes when you change orientation
cheers
Paul
djphillyp
Re: Play Store Beta
Postby daneren2005 » Mon Apr 28, 2014 2:05 pm
Alright, fixed. I also already fixed another issue with pull to refresh being triggered when it shouldn't be. I'll probably be updating later tonight if no one else brings anything else up.
Re: Play Store Beta
Postby ar9 » Tue Apr 29, 2014 3:09 am
This issue has been present throughout all DSubs up to this point.
When I am downloading a song (not on the same LAN), 10% of the songs will have glitches in them, or cut early.
This is likely because DSub loses focus on my Android player (Nexus 7/Galaxy S3 Mini), but what do I know?
Is there anyway to match the hash of the transcoded file on the server to the hash of the downloaded file or is that beyond the scope of DSub?
If mismatched, redownload.
ar9
Re: Play Store Beta
Postby daneren2005 » Tue Apr 29, 2014 4:25 am
The question really has nothing to do with the Beta. Do you want to move this discussion to either a new thread, or in the main DSub topic thread?
Re: Play Store Beta
Postby ar9 » Tue Apr 29, 2014 2:04 pm
daneren2005 wrote:The question really has nothing to do with the Beta. Do you want to move this discussion to either a new thread, or in the main DSub topic thread?
Sorry, yes I do.
I don't know why I posted it here. :S
ar9
Re: Play Store Beta
Postby wesssider » Wed Apr 30, 2014 12:07 am
daneren2005 wrote:I'm probably not going to make it configurable. That would require a crap ton of duplicated code. What lists do you have that large that require a lot of swiping through? I can add it to the album lists like Recently Added pretty easily, but do you really have artists with that many albums to swipe through?
Thank you for enabling fast scroll on the 'Album Lists'. If large art isn't going to be configurable that's the reason I requested 'fast scroll' in 'Library' because my folders structure is mostly flat.
wesssider
Re: Play Store Beta
Postby wesssider » Fri May 02, 2014 5:01 am
Thank you for making the large art configurable! Nice surprise. Donation time!..
wesssider
Re: Play Store Beta
Postby daneren2005 » Fri May 02, 2014 5:21 am
Sweet thank you :D
Re: Play Store Beta
Postby daneren2005 » Thu Jun 12, 2014 4:42 am
New beta with admin tab + various improvements/bug fixes.
Re: Play Store Beta
Postby grumpwagon » Sun Jan 25, 2015 3:51 am
Just joined the beta project (running 4.9 beta 3). There are some great features here, thanks for your continued work on it.
I love pulling the last.fm artist info from the subsonic server, and the ability to see related artists. I didn't see a way to play (or shuffle play) all related artists, like the "similar artist radio" feature on the web subsonic client. Is it there and I missed it? If not, adding an option in the settings dropdown would be much appreciated.
Secondly, it seems like you hold off loading the artist window (i.e. go to library, select an artist) until the server loads the last.fm info. This causes loads to take longer than expected. I'm not sure how challenging this is, but is there any way you could handle this like the web client does (i.e. display the album list right away, then display the last.fm info when it loads)? I haven't seen consistent behavior on the web side about how subsonic caches the last.fm info, so if this is a problem that will go away once subsonic gets the artist info cached, feel free to ignore this.
grumpwagon
Return to DSub for Android
