GENRE Problem
GENRE Problem
Postby foksaexploz » Wed Jan 29, 2014 10:59 am
Hello everyone,
Today i installed DSub that i used some time ago. I think i set up my server properly as the library shows up and i can play songs on my phone.
I have a problem whith the Genre tab though which shows "None found" and in the Shuffle tab, the only choice for Genre browsing i get is "Blank".
All my library is properly tagged in Genre field in my PC (IDV3V2 tags) and i recall it worked last time i used DSub (That's why i used this app over the Subsonic app), my Genres all showed up and could shuffle 20 songs by a genre of my choice few months back.
Has anyone encountered this problem already or did i do something wrong?
Thanks for your answers.
foksaexploz
Re: GENRE Problem
Postby mr_nobody » Wed Jan 29, 2014 1:11 pm
Those tabs only work with server version 4.9. Are you running that?
If so, try connecting to the demo server and then reconnecting to your server to see if they refresh.
mr_nobody
Re: GENRE Problem
Postby daneren2005 » Wed Jan 29, 2014 3:38 pm
What server version are you using?
Sent from my HTC One X using Tapatalk
Re: GENRE Problem
Postby foksaexploz » Wed Jan 29, 2014 4:42 pm
Damn how do i know which version i'm running?
Is there a way to change version of server?
Thanks for the quick answers!
foksaexploz
Re: GENRE Problem
Postby mr_nobody » Wed Jan 29, 2014 4:48 pm
Log into the web app and click About.
You change the server version by upgrading to a newer version.
mr_nobody
Re: GENRE Problem
Postby foksaexploz » Wed Jan 29, 2014 8:44 pm
I checked:
Version 4.9 (build 3853) – 23 janvier 2014
Serveur jetty-6.1.x, java 1.7.0_51, Windows 7 (98,5 MB / 145,0 MB)
I tried the demo server and everything works fine, the Genres are listed but turning back to my server still "None found".
Any Ideas?
foksaexploz
Re: GENRE Problem
Postby mr_nobody » Wed Jan 29, 2014 9:08 pm
Try running a full media scan and see if that fixes it.
mr_nobody
Re: GENRE Problem
Postby nicolaibvm » Sat Nov 07, 2015 10:49 am
I have the same problem after upgrading by uninstalling old madsonic version and installing new server and set it up from scratch again.
Was there a fix for this?
nicolaibvm
Return to DSub for Android
