Samsung s5 lock screen
Postby somercamb » Wed Apr 01, 2015 7:24 pm
Hey all
Couldn't find an answer to this, but is there a way to disable the full screen album cover on the lock screen? I have a Samsung s5. It happened with s3 as well. I did see that a dsub update (2013?) stated the "ability to place large widget on lockscreen for Android 4.2+". Is there a way to turn that off or have it revert to what it used to be where it took over only the top 1/4 of the lock screen? Otherwise, it's very difficult to see the keypad to unlock the screen, especially for light colored albums. Good (or bad?) thing I don't own the White album.
Audio, another previous update stated "Display Artist instead of Album on lockscreen". Is that still a feature?
Thank you
somercamb
Re: Samsung s5 lock screen
Postby nebo » Wed Apr 29, 2015 6:09 pm
This is a "feature" in Android. You can disable it with Xposed but I'm pretty sure there is a way for a player to specify it as well which would be nice.
nebo
Postby somercamb » Wed Apr 29, 2015 7:03 pm
It actually was fixed recently with lollipop, but it only affects the Samsung stock player and maybe google music (didn't try google
somercamb
Return to DSub for Android
