4.7 Playlist path problems
Re: 4.7 Playlist path problems
Postby otis_bartleh » Mon Dec 31, 2012 5:38 pm
sindre_mehus wrote:Hi,
I should probably also add the "Playlist folder" user setting again.
Cheers
None of my playlists have worked since "upgrading" to 4.7, and those are what I almost always use. I know I would really appreciate the Playlist folder coming back. I create playlists from different apps and programs, and sometimes by directly editing in notepad, so bringing that back would be great.
otis_bartleh
Postby dhilberg » Thu Jan 03, 2013 7:38 pm
Additionally, it would be nice to have the ability to import playlists that exist on the server from the Subsonic web interface when using it remotely.
Currently in 4.7, when you attempt to import a playlist a dialog box opens on the local machine. If I'm at work and want to import a playlist that exists on the server (at home), I have to remote into the machine and open the Subsonic interface there.
You cannot import a playlist local to the server unless you're using Subsonic on the server itself.
dhilberg
Postby jaume » Tue Jan 08, 2013 12:44 pm
The playlist folder feature would really suit me too. It was way more practical to upload the playlists as needed and to be able to do it remotely from the server. Also, if I made changes to the playlists using the server machine, I would always have access to the latest version. Now, I need to delete it from subsonic and re-upload it every time I make a change.
jaume
Postby devroute » Wed Jan 23, 2013 9:21 pm
I guess a simple fix to improve the situation would be to automatically re-import a playlist if the timestamp of the file has changed.
Cheers
This would be great!
devroute
Postby wdpaynter » Sun Feb 03, 2013 3:46 pm
I too, prefer the "old" play list folder. In the meantime, how do I delete and add play lists manually in the current 4.7 setup. I am really confused...
Any help/explanation would be appreciated.
BP
wdpaynter
Postby jaume » Sun Feb 03, 2013 5:26 pm
With 4.7 playlists can only be added from the local host PC. You need to click on Add on the left hand side pane and point to the playlist location. If you make changes to the local playlist, you need to follow the same process in order to update it on the server.
Hope this helps.
jaume
Postby wdpaynter » Sun Feb 03, 2013 5:55 pm
jaume wrote:With 4.7 playlists can only be added from the local host PC. You need to click on Add on the left hand side pane and point to the playlist location. If you make changes to the local playlist, you need to follow the same process in order to update it on the server.
Hope this helps.
Thanks for the reply!
I see, but we really need a way to delete multiple playlists and add multiple playlists (like it was before). Seems this way, you can only delete one at a time. Maybe adding the playlist directory to the "Scanned Folders" list will add multiple playlists?? But, could this create duplicate songs??
I'd like for it to go back to the way it was (or a combo of the two).
BP
wdpaynter
Postby Glader » Mon Mar 25, 2013 11:44 am
Any estimation for when and how the old functionality will be re-implemented? :)
Glader
Postby bushman4 » Mon Mar 25, 2013 12:42 pm
We have had no comment from the developer as to if or when he will change a given feature. So unless he chooses to reply to you, there is no way to know.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby mockingbrd » Thu Mar 28, 2013 4:45 pm
I really wish this would have been fixed by now. I've been patiently waiting for a fix since last year. I've all but ceased creating playlists for Subsonic because of how they're handled in 4.7. It's maddening to have to re-import a playlist each time I make a change to said playlist in Foobar or my media player of choice. The only thing more frustrating is trying to edit playlists using Subsonic's archaic playlist editing functionality. How difficult is it to downgrade to 4.6 from 4.7?
mockingbrd
Postby bushman4 » Thu Mar 28, 2013 7:22 pm
I just want to make something clear... there is really nothing to fix here. You fix a big. You change or add a feature.
The new database stored playlists work exactly as they are supposed to.
They just work in a method that people don't seem to like...
Just semantics, but important to a developer. A bug fix is different than a feature change.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby zapt0 » Sat Apr 06, 2013 5:38 pm
bushman4 wrote:I just want to make something clear... there is really nothing to fix here. You fix a big. You change or add a feature.
Glenn
The playlist issue is not a bug, it's a feature regression.
Ideally, if Sindre cared about the users of his software there would be a version 4.7.1 that fixes this.
zapt0
Postby Glader » Sat Apr 13, 2013 3:07 pm
bushman4: It's an undocumented feature. One that more people than just me seem to be using. Without it it's more or less impossible to use subsonic together with other players since it maintains its own proprietary database over playlists which you cannot influence externally.
It's not just semantics, it's a question of what subsonic is used for.
We also DO have a comment from the developer regarding it, it's on page 1:
Cheers
So we do have acknowledgement from the developer about the feature regression and I would still appreciate an update on when we can expect a replacement, I'm eagerly hoping to upgrade from 4.6. :)
Glader
Postby bushman4 » Sun Apr 14, 2013 1:03 am
He only mentions import, not export.
But if he chooses to change it, so be it. No skin off my teeth.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Previous
Users browsing this forum: No registered users and 48 guests
