external hd wont scan [Resolved]
Re: external hd wont scan
Postby GJ51 » Wed Sep 19, 2012 6:09 pm
shenery wrote:Ok i put in BIGSACKS which is the log on name for the pc and then the password.It then said that changes wont be made till you restart the service.
The administrator? There is only one account on the pc and thats BIGSACKS. Does that mean its the administrator?
Yes you will need to restart the Subsonic service. You should be able to do that by a right click on the green tray icon then click on Stop - wait till the icon turns red - click Start - then wait till it turns green.
Then go back into subsonic and see if it reads the drive.
Postby shenery » Wed Sep 19, 2012 6:25 pm
shenery
Postby shenery » Wed Sep 19, 2012 6:30 pm
And also. I restarted the service.
shenery
Postby hakko » Wed Sep 19, 2012 6:35 pm
Just wanted to add - there's probably a button called "PrtScr" on your keyboard, normally up above the Insert, PageDown etc. If you press it, it takes a screenshot of the windows you see on your screen and copies it as a picture to your clipboard. If you press Alt+PrtScr, only the active window is included in the screenshot. You can paste that immediately on a site like imgur.com. It might be easier than using a camera?
MusicCabinet developer
hakko
Postby GJ51 » Wed Sep 19, 2012 6:41 pm
B:\
Use B:\
Even the correct slash is important.
You should also have your music in a folder, such as B:\Music
Create B:\Music - put in a few folders with music in each one.
Enter B:\Music in the Media Folders entry.
Scan
Enjoy
You need to develop a better eye for detail.
If you've been trying to get B:/ working all this time - that has been the source of the problem the whole time.
Postby shenery » Wed Sep 19, 2012 6:50 pm
I swear i have a folder called b:\music ive tried b:\ and b:\music. Its just not working
shenery
Postby GJ51 » Wed Sep 19, 2012 6:58 pm
shenery wrote:I swear i have a folder called b:\music ive tried b:\ and b:\music. Its just not working
Well, if you look in the image you posted above, you entered B:/
I know for sure that that entry won't work.
Postby shenery » Wed Sep 19, 2012 7:01 pm
Ok maybe that time. But ive been trying it the other way and still no dice
shenery
Postby GJ51 » Wed Sep 19, 2012 7:12 pm
The only other thing that I can think of is that B: is usually used for floppy drives.
Postby shenery » Wed Sep 19, 2012 7:20 pm
Ok ill change it back and let you know then
shenery
Postby shenery » Wed Sep 19, 2012 7:45 pm
Praise the fuc#&ing lord!
Dont think subsonic likes B:\ changed it to G:\ and my files are scanning.
Cheers again man
shenery
Postby GJ51 » Wed Sep 19, 2012 9:24 pm
Sometimes us old timers just know instinctively what NOT to do. The B: drive is usually defined in most bios entries as a floppy drive and the system expects that it's not used as a hard drive entry. It therefore can't recognize and interpret the file system properly.
Experience is a marvelous teacher isn't it? :wink:
Postby BKKKPewsey » Wed Sep 19, 2012 10:31 pm
And in under 2 pages GJ as well :lol:
Your next assignment Mr Phelps will be ........
Damn the tape just caught on fire!!!!
Postby shenery » Wed Sep 19, 2012 11:41 pm
Cracking mate.
Listening to my tunes remotely as we speak ;-)
Technology can an absolute bastard but an absolute delight too.
shenery
Previous
