FLAC->OGG Transcode playback problem in Android app
Re: FLAC->OGG Transcode playback problem in Android app
Postby rage4order » Wed Nov 21, 2012 6:16 am
Oh yeah, it happens on my Nexus 7 with stock firmware. Currently running 4.2, but it was doing it on 4.1.2 as well.
The problem is not limited to just Galaxy Nexus.
Sent from my Nexus 7 using Tapatalk 2
rage4order
Postby daneren2005 » Wed Nov 21, 2012 6:25 am
Alright I haven't really tested much on my 7 other than to make sure the layout looked okay so I will have to take a look and see if I can reproduce the problem there. Is there anything I can do to make it more obvious of a problem?
Sent from my HTC One XL using Tapatalk 2
Postby GJ51 » Wed Nov 21, 2012 6:38 am
I usually just make sure to test with an album that isn't pinned or in the cache. Does the same thing just about every time. the first track plays for a few seconds, sometimes does a little hiccup, or pauses then jumps back to the beginning of the track. Then it will play to somewhere around a little more than a half to about 3/4 and then jump to track 2. Subsequent tracks play properly after that.
Postby hyatari » Wed Nov 21, 2012 10:22 pm
daneren2005 wrote:Alright I haven't really tested much on my 7 other than to make sure the layout looked okay so I will have to take a look and see if I can reproduce the problem there. Is there anything I can do to make it more obvious of a problem?
Use this transcoding line flac > ogg : ffmpeg -v 0 -i %s -f ogg -vn -acodec libvorbis -ar 44100 -aq 3 -ac 2 -map_meta_data 0:0 -
and the issue described above happens every time consistently on my galaxy nexus.
My theory was wrong about internal memory vs external sd cards. i just tested on my tablet running cm10 android 4.1.2. Caching to internal memory and then external sd card made no difference the problem still exists either way. So this definitely appears to be an android jellybean issue.
hyatari
Postby daneren2005 » Fri Dec 07, 2012 6:22 am
I can't figure out how I'm supposed to change the transcoding to be flac -> ogg. Is anyone willing to give me a dummy account with some sample transcoded songs to look at? I can't get these same issues to happen with a Nexus 7 for mp3 files
Postby GJ51 » Fri Dec 07, 2012 6:36 am
daneren2005 wrote:I can't figure out how I'm supposed to change the transcoding to be flac -> ogg. Is anyone willing to give me a dummy account with some sample transcoded songs to look at? I can't get these same issues to happen with a Nexus 7 for mp3 files
You don't have the PM option available. I can set up a test for you if you'd like. Send me a PM so I can give you access to my server.
I also use google+ or Skype if you want a live session.
Postby hyatari » Sat Dec 08, 2012 11:59 pm
sent you a pm with details to access my server.
hyatari
Previous
