DLNA just expands more and more, eg audio/audio/audio/audio
Re: DLNA just expands more and more, eg audio/audio/audio/au
Postby AzzMG » Sun Mar 23, 2014 12:04 pm
Has this problem as well. Using Ubuntu 12.04.4 server.
I'm also a premium member and would also like to hear from a developer about this
Skickat från min GT-I9300 via Tapatalk
Using Tapatalk
AzzMG
Postby jakecrow » Sun Mar 23, 2014 11:44 pm
I used to have no problems with this until one day when it did the same thing as you all are describing. Since it had been working just fine I figure SOMETHING had changed but all my settings were correct and I knew I hadn't touched any Subsonic settings anyway.
So right to the point I fixed my issues by splitting my music folder into two separate folders and re-synching them with Subsonic. Maybe there is a limit to the number of files or subfolders you can have in one directory? Sounds goofy I know, but it instantly fixed the problem for me. I realize it's not the most elegant solution but it's better than not being able to stream at all.
jakecrow
Postby RecceDG » Mon Mar 31, 2014 10:37 am
Bump. Does the Dev read this forum at all?
RecceDG
Postby sindre_mehus » Tue May 27, 2014 6:17 am
I'm looking into this problem now, but I'm not able to reproduce. On my server it works with foobar2000, Samsung Smart TV and misc Android apps.
This leads me to believe that the bug could be data dependent (e.g., based on the characteristics of the media library).
If someone who has this problem could create a temporary account for me on their Subsonic server (for me to take a look at the file structure), that would be most helpful.
Also, (more) log files would help.
Thanks, and sorry for the late reply.
Postby daneren2005 » Tue May 27, 2014 2:37 pm
There is another thread here somewhere where I already found the issue and made a fix for it with a link to the commit. It only happens when you are trying to expand folder with id 0 and it is because that is also the root node.
Postby sindre_mehus » Tue May 27, 2014 2:46 pm
daneren2005 wrote:There is another thread here somewhere where I already found the issue and made a fix for it with a link to the commit. It only happens when you are trying to expand folder with id 0 and it is because that is also the root node.
Ah, wonderful! I found your fix and will apply it. Thanks a lot and sorry for the negligence!
Postby AgentBignose » Wed Jun 18, 2014 7:14 am
is this problem fixed in the meantime? I have 5.0.beta1 (build 4046) running on my server and still have the expanding loop on my first folder which is music.
Further, if I want to play anything via DLNA from Subsonic on my Samsung Smart TV (its possible to display theother root folders for example Videos or Playlists), theres just an error message box "Check network connecting" which of course is fine.
What am I doning wrong?
Thx, Stefan
AgentBignose
Postby KBanause » Mon Jun 30, 2014 11:09 am
AgentBignose wrote:Hello,
I have this problem too.
Here's the output of the log file for the attempts to change the directory:
[2014-06-29 14:46:56,918] INFO FolderBasedContentDirectory - UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,upnp:genre,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[2014-06-29 14:47:05,318] INFO FolderBasedContentDirectory - UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,upnp:genre,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[2014-06-29 14:47:07,685] INFO FolderBasedContentDirectory - UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,upnp:genre,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[2014-06-29 14:47:09,409] INFO FolderBasedContentDirectory - UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,upnp:genre,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[2014-06-29 14:47:10,068] INFO FolderBasedContentDirectory - UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,upnp:genre,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
KBanause
Postby sindre_mehus » Mon Jun 30, 2014 1:12 pm
It's fixed in 5.0.beta2 (not yet released)
Regards
Postby cnschulz » Sat Jul 12, 2014 4:56 am
two thumbs up! cant wait.
cnschulz
Postby avinashmeetoo » Mon Jul 28, 2014 7:23 pm
Hi Sindre,
Can you please tell me when beta2 will be released? I can't listen to music on my Yamaha receiver and this is driving me nuts 8)
Avinash
avinashmeetoo
Postby KBanause » Mon Jul 28, 2014 8:49 pm
avinashmeetoo wrote:Hi Sindre,
Avinash
I'm also waiting for it. In the meantime I'm using mediatomb as a DLNA server.
KBanause
Previous
Users browsing this forum: No registered users and 114 guests
