[Resolved] SS App on KitKat not downloading Music to SD Card
Re: [Resolved] SS App on KitKat not downloading Music to SD
Postby bignose2 » Mon Apr 14, 2014 1:28 pm
Not working for me.
SGS4 Kitkat 4.4.2
DSub
Use to work & still works if I set it to the internal memory.
Dsub set the default folder as above extsdcard/github... files/music
It actually has created the folder fine but Dsub would not play or cache.
Looking as location using Astro the folder is there OK but I cannot copy any files to it or the folder above
Strange it let DSub create the folder but nothing else can be written.
Very annoying..
bignose2
Postby daneren2005 » Mon Apr 14, 2014 2:15 pm
Try sending me a log (Home - Send Log) after trying to download a song and it failing. I can try to take a look at it.
Postby pedro_fr » Mon Apr 14, 2014 4:49 pm
With thé root foldermont. Apk
Envoyé depuis mon GT-I9505XXUEMKF avec tapatalk
pedro_fr
Postby bignose2 » Tue Apr 15, 2014 1:24 pm
Fixed.
It is now working which is really weird.
I refreshed the server music a few times but I had already done that lots of times but it must have just cleared something.
Hopefully will stay OK and was just a blip as is usually reliable.
Thanks anyway.
bignose2
Postby rnorris » Thu Apr 17, 2014 12:07 pm
Been trying to get this working and finally figured out what I was doing wrong. Not sure if I had missed an instruction, but thought that if I had then others might too and this will help them.
I was trying to manually create the folder (as described earlier in this thread) and then point the Subsonic app at it; but it would not work. Then I went into the "settings\apps\subsonic\" and selected "move" to move the App to the SD card. This allowed the app to use the folder "sd_card\Android\data\net.sourceforge.subsonic.androidapp" which I then moved all my existing music into.
Hope this helps anyone else with the same problem.
Rob
rnorris
Postby hogman4prez » Sun Apr 20, 2014 6:40 pm
Does anyone have a solution specfically for Galaxy S5? I have tried changing the cache location to the one listed without success. i have also tried moving the app to the sd card without any luck
thanks
UPDATE-- I tried moving to SD card and I was able to get mine to work finally as well. Thanks for the advice:
hogman4prez
Postby aeschulus » Tue Apr 22, 2014 7:24 pm
Rob's suggestion of moving the app to the SD card worked for me - and I ran into an additional hurdle. I'm used to using the Astro File Manager, but trying to create the folder underneath /storage/extSdCard/Android... wasn't working. I had to use the built-in file manager app "My Files" in order for it to create the folder, but from there it worked out great!
aeschulus
Postby Ileclerk » Tue Apr 22, 2014 9:09 pm
That worked on mine as well. Thanks!
Ileclerk
Postby nmos » Mon May 05, 2014 10:18 pm
I'm sure glad I found this post because this bug was driving me nuts.
One thing I haven't seen mentioned is that this issue could end up causing massive data usage for some people. I have a little data monitor on my phone that shows transfer speeds in real time and when this problem hit my phone was downloading at 40Mb/s and just keept going until I cleared the queue. Since this was on my wifi it wasn't a problem but imagine someone who runs into this while using a metered connection and decides to put off trying to troubleshoot it for a few days.
nmos
Postby BioSOre » Wed May 07, 2014 1:34 am
^^ This. This is exactly what happened to be this past Friday evening. My monthly quota had just been reset two days prior and I received a text saying I had used 65% of my data quota. Opened the settings and saw that the application had used 1.6 gigs in 24 hours.... I was shocked.
BioSOre
Postby Ileclerk » Fri May 09, 2014 12:20 am
This is no longet resolved by just disallowing the custom directory. Now my phone storage is used instead of my SD card. The workaround here worked fine. :oops:
Ileclerk
Postby NexceveN » Sat May 17, 2014 8:57 pm
I'm sorry to say that I still have the problem on my phone. I can browse my library, but can't play songs (Downloading 0b).
Some tech specs.
Using a Samsung Note III with android 4.4.2 running.
Using Subsonic client 4.3
Using Subsonic server 4.9
Cache folder is set to /storage/emulated/0/subsonic
I can't move the app to my SD card, it says I don't have a SDcard :? very strange, because I do have a sdcard.
My wife has a Note II with android 4.3 and this device can still play all the songs, but she isn't using the newest client version from the play store.
If additional information is required, please ask. I'll do my best to help.
NexceveN
Postby FUNKILL » Mon May 19, 2014 5:49 pm
NexceveN wrote:I'm sorry to say that I still have the problem on my phone. I can browse my library, but can't play songs (Downloading 0b).
Some tech specs.
This is simular to my problem. The one difference is that i DONT have a SD-Card. It wont play songs (Downloading 0b), but still used up my quota (90%) This started after latest update of APP. worked flawlessly before the update.
Device is Sony Experia Z1 Compact w/kitkat.
Tried uninstall, clear all data,change cache size, but no luck in making it work.
FUNKILL
Postby vbs » Tue May 20, 2014 11:47 am
Similar problem for me. Until today it was working fine but now I cant play music anymore at all :cry: I found out that all my music went from the external SDCard (sdcard1) to the internal memory (sdcard) which is also quite sad (I bought an 32GB SD-card just to store my subsonic music there). It does not show any offline music anymore even though all music is available in /sdcard/subsonic/music
Also I am not able to change the cache location anymore.
Running 4.3.1 on Sony Z1 compact.
Please help!
vbs
Postby NexceveN » Tue May 20, 2014 6:37 pm
Some tech specs.
Yesterday's client update Subsonic 4.3.1 fixed my issue. Thank you kindly!
I hope the problem will be fixed soon for the others.
NexceveN
Users browsing this forum: No registered users and 111 guests
