Jukebox: Audio Device Unavailable
Postby bsantero » Tue Mar 01, 2011 10:37 pm
I'm still having trouble :(
I used to get the "Error in BasicPlayer.play()" message. Opened Synaptic, uninstalled all the Open java packages I could find. restarted. Installed all the sun-java6-jdk packages, their dependencies, made sure mplayer will play an mp3 (it does).
And it still doesn't do anything.
I don't get the error anymore, but the log will say
[3/1/11 5:21:16 PM EST]   INFO   JukeboxService   Starting jukebox player on behalf of CoolBone
[3/1/11 5:21:16 PM EST]   INFO   PlaylistInputStream   CoolBone listening to "Aarhus Brass Quintet/02 Allegro Moderato.mp3"
[3/1/11 5:21:16 PM EST]   DEBUG   JukeboxService   stateUpdated : OPENING:-1:java.io.BufferedInputStream@7afbd1fc
[3/1/11 5:21:16 PM EST]   DEBUG   JukeboxService   opened : {mp3.id3tag.track=2/19, mp3.crc=false, mp3.id3tag.encoded=iTunes v6.0.4, mp3.copyright=true, album=Aarhus Brass Quintet, mp3.channels=2, mp3.version.mpeg=1, mp3.id3tag.genre=Other Classical, mp3.framesize.bytes=518, title=Allegro Moderato, mp3.version.layer=3, mp3.id3tag.composer=Victor Ewald, mp3.vbr.scale=0, mp3.bitrate.nominal.bps=160000, mp3.version.encoding=MPEG1L3, audio.type=MP3, mp3.id3tag.v2=java.io.ByteArrayInputStream@1c6250d2, vbr=false, mp3.id3tag.v2.version=3, mp3.padding=false, audio.framerate.fps=38.28125, audio.channels=2, mp3.framerate.fps=38.28125, mp3.header.pos=67943, mp3.frequency.hz=44100, basicplayer.sourcedataline=com.sun.media.sound.DirectAudioDevice$DirectSDL@59bd523d, bitrate=160000, mp3.mode=1, comment=Cleaned by TuneUp!, mp3.vbr=false, audio.samplerate.hz=44100.0, mp3.original=false}
[3/1/11 5:21:16 PM EST]   DEBUG   JukeboxService   stateUpdated : OPENED:-1
[3/1/11 5:21:16 PM EST]   DEBUG   JukeboxService   stateUpdated : PLAYING:-1
[3/1/11 5:21:16 PM EST]   DEBUG   JukeboxService   stateUpdated : GAIN:0.850000023841857
Sigh, anybody having this?
bsantero
Problem solved
Postby regisb » Tue Apr 26, 2011 9:39 pm
Switching to the Sun Java6 JDK worked for me, too:
sudo apt-get install sun-java6-jdk
sudo update-alternatives --config java
sudo /etc/init.d/subsonic restart
regisb
Tag V2
Postby lucquebec » Sun Jun 26, 2011 3:39 am
My Jukebox player not working whit some mp3 files and playing very well with other one.
AND
I have 1.6 sun java system on Ubuntu 11.04
I found this solution :
It appear than some mp3 tag, like ID3 V2 with picture is not supported by the Subsonic java jukebox and you get Error in BasicPlayer.play() in your log. I remove ID3 V2 tags and keep only the ID3 V1 mp3 tags and the Jukebox playing very well after that. I suggest Kid3 on linux Ubuntu if you hope remove ID3 V2 tag.
lucquebec
Re: Tag V2
Postby nate5182 » Thu Jul 14, 2011 3:04 am
lucquebec wrote:My Jukebox player not working whit some mp3 files and playing very well with other one.
AND
I have noticed this same issue. I can't play tracks with album art stored in the ID3 tags in jukebox mode. Anybody know why this is?
nate5182
Re: Jukebox: Audio Device Unavailable
Postby structurefall » Sun Aug 28, 2011 7:07 pm
has anybody come up with any other solutions to this? i'm running ubuntu 11.04 and this seems to be happening mostly on VBR mp3s, and it's driving me completely nuts.
i already completely removed openjdk and i'm just using sun now. i recently rebuilt my system- it was previously centOS 5.4- and had the same problem with the same files there.
fazel- could you share more details about your mplayer hack? i'd like to try that.
structurefall
Postby structurefall » Sun Aug 28, 2011 7:17 pm
oh hey so, i just found an easy and awesome workaround.
this appears to only happen with certain high-bitrate and VBR mp3s, but you can set a maximum bitrate for the jukebox. i set mine to 224, and it works!
it's a slightly crappy solution because it means i'm hearing stuff at a lower bitrate... but a lot of my collection is at 192 anyhow, and i can't really hear the difference. hopefully a real fix will show up eventually, but now at least i can listen to everything.
hope that helps, guys!
structurefall
Postby SiliconS » Thu Feb 16, 2012 5:52 pm
I'd like to bump this thread with thanks to both gygys and mememot for the help you guys posted a year ago.
SiliconS
Postby igeman » Tue Oct 09, 2012 6:11 am
So I see this thread is quite old but I found a solution that makes work all my mp3 files. In special I faced a problem playing files with cover art inside.
The solution is quite easy (found on a blog):
(http://www.pelzkuh.de/2012/10/funkstill ... m-mp3.html) It is in German but mainly says that the cause is an outdated library mp3spi1.9.4.jar. You have to replace it with the new one mp3spi1.9.5.jar. Links are provided in the pelzkuh blog entry.
I replaced the library and tada :-) working. I searched a lot of time so I think this post here makes sense altough it is quite old
igeman
Postby TeChn4K » Sun Nov 04, 2012 7:13 pm
My Subsonic installation is running with Ubuntu Server, and now jukebox mode works great for me !
Thanks to walkerpett and Gygys !
TeChn4K
Previous
Users browsing this forum: No registered users and 145 guests
