Skipping tracks
Postby utopian » Sun Dec 05, 2010 11:27 am
sometimes when i hit play all it skips to track 2..any ideas anyone.. this is very annoying...
utopian
Postby GJ51 » Tue Dec 07, 2010 4:29 am
Have you tested other servers, or had someone else test yours? Does someone else from outside get the same issue?
I ask because I get some wierd behaviors and connection issues with IE9 beta that I don't get with Chrome.
Postby utopian » Wed Dec 08, 2010 10:37 am
don't have anyone else accessing other than myself from inside/outside LAN.. using Firefox.. are there any known issues with this browser possibly ??
utopian
Postby GJ51 » Wed Dec 08, 2010 4:16 pm
I have SS ver 4.1 set up on my WHS.
http://maplegrove.homeserver.com:8083
guest
guest
Browse in and see if you have any problems. If you don't, then we know the problem is on your server.
Postby utopian » Wed Dec 15, 2010 9:36 am
thanks for that.. tried a few tunes and they didn't skip.. noticed they were mp3 whereas mine are all m4a.. is this causing the problem then...
utopian
Postby GJ51 » Wed Dec 15, 2010 3:43 pm
Very possible. I do have some m4a's in there somewher. I've never had a problem with them, but it does seem they do cause difficulties for som SS users.
How is you're transcoding set up?
Do you want me to test your site on my phone?
Postby GJ51 » Wed Dec 15, 2010 7:54 pm
One step with a fixed bit rate (all tags transferred to MP3)
Step 1: ffmpeg -i %s -f mp3 -ar 44100 -ab 320k -ac 2 -map_meta_data 0:0 -
Step 2: none (blank)
or two step transcoding (above is a better choice)
Step 1: ffmpeg -i %s -f wav -ar 44100 -ac 2 -
Step 2: lame --preset cbr %b -S --tt %t --ta %a --tl %l - -
See also http://forum.subsonic.org/forum/viewtop ... 7540#17540
PP: Mark check boxes right from Step 3 and check players settings (log as admin to see all players).
Try this for the transcoding.
Thanks to Stozher for the info. He da man when it comes to transcoding!
http://forum.subsonic.org/forum/viewtopic.php?t=4914
Postby utopian » Sun Jan 16, 2011 11:53 am
not sure whats happened but my skipping seems to be cured.. running with the latest version (maybe that sorted it somehow...) :)
utopian
Previous
