M4A transcoding failing
Postby tumtum1088 » Thu Dec 09, 2010 6:02 pm
I can't seem to get my web player or my android app to play M4A files. I'm running the most recent versions on both. They load up album art and song length but stay at 0 when i hit play. On the android app it gives an "prepare failed.: status 0x1(IO Exception "status error. Any help would be appreciated. - Thanks , Tumtum1088
tumtum1088
Postby stozher » Thu Dec 09, 2010 7:11 pm
One step with a fixed bit rate (all tags transferred to MP3)
Step 1: ffmpeg -i %s -f mp3 -ar 44100 -ab 320k -ac 2 -map_meta_data 0:0 -
Step 2: none (blank)
or two step transcoding (above is a better choice)
Step 1: ffmpeg -i %s -f wav -ar 44100 -ac 2 -
Step 2: lame --preset cbr %b -S --tt %t --ta %a --tl %l - -
See also http://forum.subsonic.org/forum/viewtopic.php?p=17540#17540
PP: Mark check boxes right from Step 3 and check players settings (log as admin to see all players).
stozher
Working again
Postby TJungus » Wed Dec 15, 2010 6:33 pm
Stozher, thank you for this information! I now have access to listen to ALL my music!
TJungus
Postby sonicdivx » Tue Jan 04, 2011 3:35 pm
@stozher
Thanks for the post, was haviing the same issue upon upgrading to newest beta.
sonicdivx
Postby stozher » Tue Jan 04, 2011 5:04 pm
stozher
Postby sonicdivx » Thu Jan 06, 2011 4:27 pm
I am still getting the Prepare failed: status=0x1 (IOException) error. regardle of method I use.
do I need to restart server or do something else (increase server memory setting, maybe)
[EDIT] this is on an Android phone and occurs on both Wi-fi and Data network
thanks
sonicdivx
