4.2 Problem
re
Postby pcs800 » Tue Nov 30, 2010 1:27 pm
Windows event log? Nothing.
Are there error logs produced by subsonic? If so, where?
pcs800
re
Postby pcs800 » Tue Nov 30, 2010 2:00 pm
subsonic-service.log
2875 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@a01335: display name [org.springframework.context.support.ClassPathXmlApplicationContext@a01335]; startup date [Tue Nov 30 08:47:38 EST 2010]; root of context hierarchy
9141 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
27360 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@a01335]: org.springframework.beans.factory.support.DefaultListableBeanFactory@11d0a4f
28719 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@11d0a4f: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
32125 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\1908
36907 [main] INFO org.mortbay.log - jetty-6.1.x
48047 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:90
Subsonic running on http://localhost:90/
48578 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
52860 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
53657 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[198.111.223.46:9412](local),objID:[0:0:0, 0]]]]
pcs800
ok
Postby pcs800 » Tue Nov 30, 2010 3:28 pm
After installing the latest version on my new machine, didn't work. Installed beta version, didn't work. Installed latest again, worked.
What I have noticed is one version installs at C:\subsonic, the other at C:\Program Files\Subsonic
Could this be the cause of all the headaches?
pcs800
Postby tenkely » Thu Dec 02, 2010 5:45 am
Same 404 error here. just upgraded today running 64bit Win7. 4.1 worked wonderfully, now nothing... did anyone find a solution?
tenkely
re
Postby pcs800 » Thu Dec 02, 2010 1:14 pm
The only solution I found is the post above. Seems like the developer is either ignoring this issue or is stumped. I don't dare install 4.2 on my second machine.
pcs800
Postby lucastswick » Thu Dec 02, 2010 8:34 pm
I had the same issue, and noticed, coincidentally, that my last java update had an error. I've reinstalled java and the issue is resolved. Hopefully that helps.
lucastswick
re
Postby pcs800 » Thu Dec 02, 2010 8:53 pm
The new machine I installed on and ultimate got 4.2 working on did not have java installed at all, so the subsonic installer did it for me. Immediately following that installation completion, no working subsonic :-(
The rest of the story is above.
The first machine currently running the beta release works fine, until I try to install 4.2, so doesn't that say java is fine?
pcs800
Postby tenchisan » Tue Dec 07, 2010 4:15 pm
I actually already reported this issue earlier but nooone responded to it.
This issue only effects windows installs where you try to run the subsonic service as a user, if you set it to run as administrator it will work. However if trying to mount the music via a samba share, you will no longer be able to. (subsonic must be run as a user with the same permissions as the samaba share to mount it)
tenchisan
Postby theemistermcd » Wed Dec 08, 2010 4:15 am
This is probably unrelated but I was getting the HTTP ERROR: 404
NOT_FOUND error on my Ubuntu server 10.04 after upgrading from 4.2 beta to 4.2. I fixed the problem by rebooting and re-installing the subsonic package.
theemistermcd
Previous
