SubSoinc.org down in Southwest United States
Postby GJ51 » Wed Mar 02, 2011 1:07 am
oldsjunkie wrote:
bushman4 wrote:Don't forget that you can always connect via IP address even if the Subsonic domain is not working.
From the subsonic server, go to www.whatismyip.com. Make a note of your IP address listed there.
Then use http://IPAddress:SubsonicPort as your web destination (or server address on a remote app) and connect directly.
I have a second server called "Home Direct" on my droid set up similar to this (but because it is a Windows Home Server I can use http://name.HomeServer.com:PortNumber, because the chance that both Subsonic AND Microsoft's domains will be unreachable is remote).
HTH,
Glenn
I see where this would be very helpful. Although wouldn't a dynamic IP cause an issue with this method? Because it's down in Indiana too, and I've been lost all day without it! :(
It's always good to know your external IP address.
Postby phokus » Wed Mar 02, 2011 2:20 am
Down in DC too. Bummer.
I use dyndns.org as a backup plan. Works swell.
phokus
Postby seanpkeown » Wed Mar 02, 2011 2:37 am
Hmm Guessing that the ip address of 208.109.0.1 is the router since its the first ip address in the 208.109.0.0/16 range.
I noticed that if you change your packet size down to 1 byte the packets seem to flow smoother.
Darn it... :?
seanpkeown
Postby ChuckzSongz » Wed Mar 02, 2011 3:32 am
Subsonic server also unreachable via URL *or* IP from Taiwan...
Just FYI! :-)
ChuckzSongz
Postby 3R3 » Wed Mar 02, 2011 1:34 pm
Setting up a dyndns redirect or two as redundancy measures is a good idea for the next ooutage. And its free :)
Just make sure your users know about it. I had the mirror links and adresses on the login page for well over 2 years and when the main redirect went down, nobody was the wiser...and the server was deserted all day.
3R3
Postby kdshaw1984 » Wed Mar 02, 2011 3:23 pm
Back up!!!
And she said keep this benzene ring around your finger, and think of me when everything you wanted starts to end...
kdshaw1984
Postby boognish523 » Thu Mar 03, 2011 9:43 pm
I am still getting the same errors, from the local host and any remote connection:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
Any ideas?
boognish523
Postby GJ51 » Thu Mar 03, 2011 10:25 pm
You have a different problem. Do you have local access to the server?
A reboot might just fix you up, if not you'll have to dig deeper. First determine if you can access SS at the server through the tray icon. Give it a right click and try to open in browser at the server. If everything runs OK that way, then you have to look at network issues and see if you can access from another computer on your local network. If that works OK, then you have to review your router setup to see why it's blocking SS at the router.
Postby boognish523 » Fri Mar 04, 2011 4:03 pm
Well, tried uninstall, reboot, reinstall, same deal. Turned off my firewall, still the same, local host, another workstation on the network, or remotely. Have been using subsonic almost a year now without any issues, I believe this started for me when I updated to 4.4.
boognish523
Postby donpearson » Fri Mar 04, 2011 4:16 pm
boognish523 wrote:Well, tried uninstall, reboot, reinstall, same deal. Turned off my firewall, still the same, local host, another workstation on the network, or remotely. Have been using subsonic almost a year now without any issues, I believe this started for me when I updated to 4.4.
Try making a new post and you may get more help with your problem.
Facebook Group:
donpearson
Postby bpm2000 » Thu Mar 10, 2011 4:17 pm
still down for everyone? Down in NW US for me, can't use subsonic without it!!!
bpm2000
Postby GJ51 » Thu Mar 10, 2011 4:27 pm
The Subsonic servers probably do not go down by region. There is only one server that handles the DNS for the subsonic.org functions. Mine is working just fine. You most likely have a different issue. Have you tried connecting to your server using your external ip address and port number. For example, you can reach my server at http://maplegrove.subsonic.org or you can get to the same server using http://98.117.185.5:8082
The only way you can be certain that the problem is with the subsonic.org server is to test both ways.
Postby donpearson » Thu Mar 10, 2011 4:30 pm
If you can get to http://www.subsonic.org then its not down...
also if it was down it would be for every one just one place.
Iv locked this topic now as its just not relevant anymore.
Facebook Group:
donpearson
Previous
