Installing on a Windows Home Server Machine
Postby GJ51 » Sun Apr 10, 2011 4:54 am
Did you disable https?
Postby JWBokx » Sun Apr 10, 2011 9:08 am
I have looked at my WHS and the only thing I can think of now is the firewall.
On my system in the firewall on tab Execptions are 2 entries for subsonic.
They are added with 'Add Program'
the first is C:\Program Files\Subsonic\subsonic-agent.exe
and the second is C:\Program Files\Subsonic\subsonic-service.exe
I can not remember if these are set by the setup, or by hand. :oops:
JWBokx
Postby GJ51 » Sun Apr 10, 2011 12:09 pm
The firewall is set up automatically by the install.
DID YOU DISABLE SSL/HTTPS????????????????
Postby tomkiki1 » Sun Apr 10, 2011 2:00 pm
Hi Gary
https is not checked on the subsonic control panel
is this what you are referring to?
I think you mean elsewhere since you said ssp/https.
Sorry to keep bugging you.
tomkiki1
Postby tomkiki1 » Sun Apr 10, 2011 2:08 pm
Windows firewall has subsonic ports 8080 and 440 open and TCP is checked.
I also turned off the firewall to test and it was no better.
I also have Mcafee managed service total protection running. It came with the ACER Aspire H320.
Any other bloat where that is known to cause problems.
firefly media server is installed. AS is Bonjour (this looks like it is a network printer program).
tomkiki1
Postby GJ51 » Sun Apr 10, 2011 2:22 pm
Mcafee could be causing problems. I've run WHS for serveral years now without any AV protection, without any problems. Most virus/malware gets into computers from email or browsing to bad sites. Since WHS is seldom used that way, it rarely gets exposed to any threats.
Re:SSL/https - Yes, I wanted you to first get the http copnnection before moving to enabling https.
If you can reach SS internally using the internal ip:port# and you can get to that port number using canyouseeme.org, then there is no reason that you shouldn't connect from outside your network, unless some other program is intercepting the traffic.
How are you testing the external address?
Postby tomkiki1 » Sun Apr 10, 2011 2:46 pm
I uninstalled mcaffee. need to reboot which I will do nest.
testing my local IP connect to SS using this on both my main PC and on the server. with the same result.
http://192.168.73.253:8080/
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
you asked me DID YOU DISABLE SSL/HTTPS
where do you disable this if not on the SS control panel.
I'm rebooting now.....
tomkiki1
Postby GJ51 » Sun Apr 10, 2011 3:15 pm
It makes more sense if your not connecting internally. Yes, if you have the box unchecked in the SS Control Panel, then SSL is disabled.
If you can't connect after the reboot, I'd suggest just doing a reinstall.
Postby tomkiki1 » Sun Apr 10, 2011 4:22 pm
Progress...
I am able to log into the SS site using the following URL in firefox
http://192.168.xx.100:8080/index.view
100 is my desktop machine which Subsonic was initially installed in. So is Subsonic is looking for my old machine? My server is 192.168.xx.243?
The subsonic web site says there are no music files. I had input the path to the music files that are on the server.
D:\shares\Music\Music Collection\
tomkiki1
Postby tomkiki1 » Sun Apr 10, 2011 4:31 pm
I was also able to log in from my server using the 192.168.xx.100 IP address.
tomkiki1
Postby GJ51 » Sun Apr 10, 2011 4:55 pm
That's the problem! You need to reset the port forwarding on the router to point to the server ip. Also, you shoud not run both SS instances on the same port #
Postby tomkiki1 » Sun Apr 10, 2011 5:52 pm
That is what I did on the router, long ago. I have rebooted the router several times.
I uninstalled subsonic on my pc.
I need to reboot once again and I will also reboot the router.
tomkiki1
Postby tomkiki1 » Sun Apr 10, 2011 6:23 pm
I rebooted the entire system, router, pc, server. subsonic is not running on PC.
Now I cannot connect to the subsonic website server at all. Port 8080 still come up open when tested. Router says the port is forwarded to the server.
I reinstalled subsonic on the server.
Also I can not connect to subsonic on my droid. The test server tests OK.
I have tried to forward other ports to the server to use them but I have not been successful. getting messages like the ISP is blocking those ports.
I'm at a complete loss.
tomkiki1
Postby GJ51 » Sun Apr 10, 2011 10:06 pm
It is possible that your ISP is blocking commonly used ports. Can you reach your WHS remote webpage?
Which ISP and router are you using?
Postby tomkiki1 » Sun Apr 10, 2011 11:40 pm
Yes, I can reach my home server remote website. XXXX.homeserver.com
I am a comcast broadband customer. My router is a Linksys E3000. less than six months old.
Gary, I really DO APPRECIATE your help.
Tom
tomkiki1
Users browsing this forum: No registered users and 42 guests
