FQDNS not resolving
Postby utopian » Wed Apr 06, 2011 8:19 am
can u ping your dns name and get a reply ??
utopian
Postby bushman4 » Wed Apr 06, 2011 1:39 pm
When you connect using the numeric IP address, do you do so over HTTP or HTTPS?
In order for HTTPS to work properly in most cases, you must first connect on the HTTP port and let it redirect you to the HTTPS port.
If you do not have both ports open on your firewall, the Subsonic service will report the error you are getting.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Wed Apr 06, 2011 2:25 pm
Under Settings/Network, is the "Access your server over the Internet using an easy-to-remember address." checked? I would also suggest NOT enableing SSL access until you've first established http access.
Previous
