sindre_mehus wrote:Glad to hear that! Thanks for reporting the problem so promptly.
GJ51 wrote:You can use any DNS service with subsonic. I use my homserver's DNS service to connect frequently. You can also just use the external ip and the port number to connect. http://108.17.27.224:8082
martyscholes wrote:GJ51 wrote:You can use any DNS service with subsonic. I use my homserver's DNS service to connect frequently. You can also just use the external ip and the port number to connect. http://108.17.27.224:8082
Thanks for the feedback. I guess my point was that the names were resolving just fine, yet my service was not operational.
I am concerned that in addition to DNS there is additional unknown reliance on subsonic.org.
As always, I could be wrong.
martyscholes wrote:During the incident, I could get to my server just fine via web or looking at folders, just not looking at music.
GJ51 wrote:Subsonic operates locally on the computer it is installed on. Ther is no necessity to interact with Subsonic.org for it to operate at it's full functionality. Setting up the redirection to the server with the subsonic.org address is just a convienience, as you can easily connect using the alternate methods I've mentioned. In your case, it is most likely that your server is not running properly. Check the local instance on the host computer to see if you can connect from inside your network.
