Tracks missing from search index
Re: Tracks missing from search index
Postby ajkessel » Sun Sep 18, 2011 8:55 pm
BKKKPewsey wrote:I am assuming that the left pane artist list is showing "The Beatles"
If so it is one of Subsonics little mysteries :roll:
Yes, they are in the left pane under B, listed as "The Beatles."
This is just one of several similar mysteries in the search results.
ajkessel
Postby BKKKPewsey » Sun Sep 18, 2011 9:33 pm
Re-reading this thread I realised that I havent got an album called "The Beatles"
Try renaming that particular album and updating the search index.
I wonder if the lucerne search index is getting confused between albums and artists although I have a number of similar albums where the artist and album name is the same and I haven't noticed a problem :?
Postby ajkessel » Sun Sep 18, 2011 10:25 pm
I just noticed something. I don't actually have any album called "The Beatles" (or folder at the album level called "The Beatles"). It seems to be confusing my top level artist folder with an album folder, and grouping it with the other Beatles albums. I can't see why that should be happening.
ajkessel
Postby BKKKPewsey » Mon Sep 19, 2011 1:54 pm
Yep looks like its definitely broke :shock:
I have found before that the easiest way to solve this type of problem is to rename the artist folder to something else eg The Beetroots :)
Update the search index then rename the fab four back to their proper name and update search again.
Let us know if that works.
Postby ajkessel » Wed Sep 21, 2011 1:12 pm
One problem solved!
It turned out I had one mp3 file in the /The Beatles/ artist folder, so it was interpreting that as an album. Now everything under /The Beatles/ is another folder (i.e. album) and the search results work as expected!
There are still some other mysteries, e.g., why there is only one Phish album when I search on Phish, but then when I click on the "Phish" artist, there are many albums. When I search on an album name in that group (e.g. "Nectar" for "Picture of Nectar") I get no relevant results, so for some reason those albums are just not getting into the index.
ajkessel
Postby grant » Thu Sep 22, 2011 8:01 pm
I'll "second" this problem.
I'm running Subsonic on windows and just upgraded to Subsonic version 4.5 thinking that this would solve this same problem that I had with an earlier version.
I've got say 124 tracks by the artist "Toto" in my collection All of the tracks are properly indexed and visible in a log file called subsonic14.index. This index is created each morning at 9:00 AM as I set it to. Unfortunately, when I search for all Toto tracks in the search "bar" at the top of Subsonic, returns the first fifteen tracks then a "more>>" link that shows ten more tracks for a total of twenty five. Why don't all 124 tracks appear? Anyone?
If I click on the subsonic navigation bar on the left, I can browse for them in that pane, but I'd like to be able to search by typing in the text.
Thoughts? Solutions?
grant
Postby BKKKPewsey » Thu Sep 22, 2011 8:33 pm
There appears to be a maximum list limit of 25 items in the search index.
I cannot get more than 25 of anything to show in search.
Postby ajkessel » Thu Sep 22, 2011 8:50 pm
BKKKPewsey wrote:There appears to be a maximum list limit of 25 items in the search index.
That could be one problem, but I don't think it's at the crux of what's happening here. If I search for a Phish album (e.g. "Junta") I get no results at all (so it can't be the 25 items issue). But if I go to the artist "Phish", there is the album, Junta, in Subsonic. And in the file system it is /Phish/Junta/files.
ajkessel
Postby BKKKPewsey » Thu Sep 22, 2011 9:22 pm
That post was ref grants post and not related to your problem.
Postby bushman4 » Fri Sep 23, 2011 12:26 pm
Is Junta tagged correctly? I'm going to look at the Search Index Code, but I think that the Search uses tag info.
(Lost my mind just a couple of times)
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby ajkessel » Fri Sep 23, 2011 2:30 pm
Yes, as best I can tell it is tagged correctly. I have 27 albums under "Phish," a mixture of ogg, mp3, and m4a files, and only one of the 27 shows up in search results. The metadata for all 27 albums (296 files) shows the same artist/album artist for every single one of them.
ajkessel
Postby grant » Fri Sep 23, 2011 3:59 pm
grant wrote:I'll "second" this problem.
I will add to this that if I search by album titles related to the artist, Toto, say, for the album Mindfields or Tambu, none of the tracks for these albums appear in the search results even though I can clearly see them in the subsonic14.index file. I can browse for them and play them, but they don't show in the search results.
I deleted the subsonic14.index file and then ran the re-indexing and the file was properly re-created, but I definitely think that somethng is broken with the search function. I hope this can get fixed.
grant
Postby BKKKPewsey » Fri Sep 23, 2011 5:31 pm
One bug that that is definitely reproducible is the way it handles an album with more then 1 disk.
E.G. If I search for Dynamic Stillness (by Steve Roach) I get the result back as "2009 - Dynamic Stillness" as the ARTIST
I then get 2 albums listed as "Dynamic Stillness" (one for each cd)
The directory structure is artist\year - album\Disk #\tracks for multiple disk albums.
So it appears to assume that one directory back from the tracks is the album and the next directory is the artist. (Which works for single cd albums)
It also shows that the artist name is being inferred from the folder structure but the album name is is coming from the ID tag (otherwise it would be called Disk 1 or 2)
This could cause problems for anyone who uses a directory structure with say tracks and artwork sub-directories within their album directory :(
Postby ajkessel » Fri Sep 23, 2011 5:33 pm
I took a look at subsonic14.index myself. There are entries for all of the albums in there. I can't see anything that distinguishes those albums that are actually returned in search results vs. those that are not.
ajkessel
Postby BKKKPewsey » Fri Sep 23, 2011 11:21 pm
The subsonic14.index appears to hold every Artist Album & track but there is also a lucene index with separate indexes for Artist Album and song.
Its in there where I think the problems may lay :roll:
