Changed internet companies...cant map port? [Solved]
Re: Changed internet companies...cant map port?
Postby pattirules » Mon Jan 02, 2012 12:22 am
doesn't work.... i will try again
pattirules
Postby pattirules » Mon Jan 02, 2012 12:26 am
ok so port forward is telling me to change it to static???????????????
pattirules
Postby ytechie » Mon Jan 02, 2012 12:32 am
Ok. Maybe this will shed some light. This is how my subsonic server is connected via dsl.
Phone line to DSL modem.
Modem to router.
The modem is set to bridge, and the router takes care of the PPPoE authentication.
The router gets its public facing IP address from the ISP.
The router is set to port forward my subsonic port to my subsonic server's IP address.
I also have my router take care of updating my dynamic dns records.
If my subsonic server is listening on port 80 (web) and its IP address is 192.168.1.101, then the mapping would map the public IP address's port 80 to the inside facing IP address of 192.168.1.101.
Your router's internal IP address should be static, and your server's IP address should be static as well. Your global IP address (provided by your ISP) should not be static, and should instead be assigned by your ISP.
ytechie
Postby pattirules » Mon Jan 02, 2012 12:36 am
# Service Name Start Port End Port Server IP Address
1 subsonic 80 80 192.168.1.9
2 SUBSONIC 4040 4040 192.168.1.9
now it says succesfully forwarding port 80 however the red icon will not turn green and i cannot access from any computer other than this one
pattirules
Postby ytechie » Mon Jan 02, 2012 12:42 am
Good news! If your server's IP address is 192.168.1.9, then your port mappings are spot on!
Try accessing your server using a different computer on the same network as your server using the address 192.168.1.9.
If that doesn't work then you are most probably having a firewall issue.
ytechie
Postby pattirules » Mon Jan 02, 2012 2:28 am
programmed subsonic to public in firewall settings now i get successfully forwarding port 80
but connection time out exception changed ip address to static new number and started over still no
pattirules
Postby ytechie » Mon Jan 02, 2012 2:59 am
So what do you have now?
ytechie
Postby pattirules » Tue Jan 03, 2012 3:35 pm
i am not sure if it is working....can you try to access lotto.subsonic.org and tell me if you can please
pattirules
Postby BKKKPewsey » Tue Jan 03, 2012 3:53 pm
I can see your server ok :)
Postby pattirules » Tue Jan 03, 2012 3:54 pm
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pattirules
Re: Changed internet companies...cant map port? [Solved]
Postby ytechie » Tue Jan 03, 2012 4:43 pm
I can see your server as well! Looks good! :D
ytechie
Previous
