subsonic.org down?
Re: subsonic.org down?
Postby troyb1 » Tue Jul 03, 2012 5:00 am
maybe im on the wrong thing. Im at the network tab under settings im sucessfully port forwarding to 8080 and where the http:// (white box) .subsonic.org is in the white box i replaced my user name with 25.30.209.234:8080 is that correct? thank you for helping me
troyb1
subsonic.org down?
Postby Chad » Tue Jul 03, 2012 5:04 am
In iSub under server put in ip addy:port
Under username put your username
Under password your password.
Chad
Postby troyb1 » Tue Jul 03, 2012 5:09 am
Chad wrote:In iSub under server put in ip addy:port
i dont have a iphone, i have an android. are you talking about isubapp.com?
troyb1
subsonic.org down?
Postby Chad » Tue Jul 03, 2012 5:09 am
There should be no subsonic.org anywhere at all.
Chad
subsonic.org down?
Postby Chad » Tue Jul 03, 2012 5:10 am
What app are you using. I have both iSub and Z-Subsonic.
Chad
subsonic.org down?
Postby Chad » Tue Jul 03, 2012 5:11 am
Try just tossing the ip and port onto a browser. It should go.
Chad
Postby troyb1 » Tue Jul 03, 2012 5:14 am
Chad wrote:What app are you using. I have both iSub and Z-Subsonic.
im just using the subsonic app for android. im very noice at this but it worked fine until an hour ago. i just dont understand what isub is. i googled it and isub media streamer comes up but its for iphone. as for the subsonic.org i was putting my ip and port in the white box from the subsonic software installed on my computer. i cant remove subsonic.org
troyb1
subsonic.org down?
Postby Chad » Tue Jul 03, 2012 5:20 am
On a computer subsonic just runs in a browser. Should on android too since it supports things apple does not ;)
Chad
Postby troyb1 » Tue Jul 03, 2012 5:24 am
Chad wrote:On a computer subsonic just runs in a browser. Should on android too since it supports things apple does not ;)
i figured it out. i was putting the info in the subsonic browser on the computer. i put the info in the subsonic app and im good but it still says it connection refused on the computer. would you recommend always using the ip and port instead of the username.subsonic.org for issues like this in the future?
troyb1
subsonic.org down?
Postby Chad » Tue Jul 03, 2012 5:29 am
Mobile yes, home no, as mine automatically goes local at home as to not chew up ISP bandwidth. So phone is always ISP addy. Use myname.subsonic.org at home and work as it selects. And is easy.
Unless it breaks. Like now, then at work I use my ISP addy as the address and at home the local address.
Fantastic you got it going though!
Chad
Postby siGh » Tue Jul 03, 2012 5:44 am
This worked for me > http:// yourname*.dyndns-server.com:8080
I haven't changed the network settings (in hope that this will all be resolved soon)
With 'shares', the same address, but with the unique share code i,e http://yourname*.dyndns-server.com:8080/share/unique identifier. I don't use a router, so am not sure if that would make any difference to the procedure.
* Obviously, 'yourname' is whatever your dyndns address is (if you have one) Stating the ... erm ... obvious really :P
siGh
Postby andvaranaut » Tue Jul 03, 2012 9:10 am
A little tip which may come in handy (it just did for me):
If you use GMail and leave it open in your Subsonic server (in a browser tab, for instance), you can find your IP by opening your GMail account, then looking for the detailed information on active connections (bottom right of the page). A list with all IPs accessing your account will pop up; you can easily find your home IP that way. Then it's just a matter of opening the IP plus the correct port (usually it's either http://xx.xx.xx.xx:6120 or https://xx.xx.xx.xx:4430)
Of course, if you run Subsonic in a dedicated box, the best solution is to setup DynDNS or something of the sort, but this trick might help.
Best regards
andvaranaut
Postby utopian » Tue Jul 03, 2012 12:00 pm
subsonic addy working fine for me...
utopian
Previous
