Resolved: Can't Connect
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 2:58 am
JusWannaJAM wrote:i'm logged into my router now
Step 3 and 4..and enter
Subsonic...4040 Ext port, 4040 Int port, BOTH for protocol, Server's IP octets, ensure 'enabled' box is checked, and SAVE.
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 2:59 am
If you haven't already done so, be sure to fix the server's IP, so it is static.
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 3:00 am
After the port has been changed..REBOOT your router. Once it comes back up, go to canyouseeme.org, and test 4040...is should say 'Success! I can see your service on port 4040!'
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 3:00 am
do i put my cpu's IP address in???
JusWannaJAM
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 3:01 am
Server ip octets is my cpu correct?
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 3:02 am
JusWannaJAM wrote:do i put my cpu's IP address in???
Yes. Recall that we need to make it static, too...we'll do that next.
Re: Can't Connect
Yep!
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 3:02 am
alphawave7 wrote:If you haven't already done so, be sure to fix the server's IP, so it is static.
it is static that i do know
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 3:03 am
eggcellent!
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 3:04 am
alphawave7 wrote:After the port has been changed..REBOOT your router. Once it comes back up, go to canyouseeme.org, and test 4040...is should say 'Success! I can see your service on port 4040!'
do i unplug my router or look for a reboot in the router menu???
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 3:06 am
I prefer a cold boot...unplug at the back, wait 30 seconds, plug it in.
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 3:06 am
k doing that now...
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 3:08 am
Once back up, make sure Subsonic service is still running, and test port @ canyouseeme.org
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 3:11 am
Error: I could not see your service on 98.16.161.163 on port (4040)
Reason: Connection timed out :evil:
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 3:13 am
JusWannaJAM wrote:Error: I could not see your service on 98.16.161.163 on port (4040)
Stop and restart Subsonic, go to settings->Network, and check the Use Easy to Remember Name...and test again @ canyouseeme
