[Resolved] SS App on KitKat not downloading Music to SD Card
Re: [Resolved] SS App on KitKat not downloading Music to SD
Postby DanielMalmgren » Fri May 23, 2014 11:10 am
vbs wrote:Similar problem for me. Until today it was working fine but now I cant play music anymore at all :cry: I found out that all my music went from the external SDCard (sdcard1) to the internal memory (sdcard) which is also quite sad (I bought an 32GB SD-card just to store my subsonic music there). It does not show any offline music anymore even though all music is available in /sdcard/subsonic/music
Also I am not able to change the cache location anymore.
Running 4.3.1 on Sony Z1 compact.
Please help!
I'm in exactly the same situation. My internal memory (/storage/sdcard) is quite crowded so I want Subsonic to use my sd card (/storage/sdcard1) but it completely refuses. If I could just understand why on earth someone would want a folder named sdcard that really has nothing with sd card to do but resides on internal memory...
I'm also on a Sony Z1 Compact, running Android 4.4.2 (CyanogenMod 11).
/Daniel
DanielMalmgren
Re: SS App on KitKat not downloading Music to SD Card
Postby DanielMalmgren » Sun Aug 31, 2014 5:54 pm
Just for the record, this problem is nothing better in version 4.4 of the app. It's really the big reason for me not using the app at all. Is there really no solution?
/Daniel
DanielMalmgren
Postby jammer » Thu Oct 09, 2014 10:46 pm
Yes, still a problem. I downgraded the app to keep using my sdcard. (S3 running cm11)
jammer
Postby DanielMalmgren » Fri Oct 10, 2014 12:41 pm
jammer wrote:Yes, still a problem. I downgraded the app to keep using my sdcard. (S3 running cm11)
Which version of the app is that? Do you have an apk anywhere that I could download? The app is really useless the way it's right now...
/Daniel
DanielMalmgren
Postby jammer » Fri Oct 10, 2014 12:53 pm
4.3 let's you specify the cache location. Worked for me but I used a utility first to restore use of the SD card for apps... I'll try to send you pm with the apk tonight...
jammer
Postby jammer » Fri Oct 10, 2014 11:41 pm
Looks like sindre leaves previous versions out on github. You'll find an apk here:
http://sourceforge.net/projects/subsoni ... oid/4.3.1/
& I had to use something like this on my phone running CM 11:
https://play.google.com/store/apps/deta ... atch&hl=en
jammer
Postby DanielMalmgren » Sat Oct 11, 2014 7:18 pm
jammer wrote:Looks like sindre leaves previous versions out on github. You'll find an apk here:
Ah, great! Thanks!
/Daniel
edit: Just for the record: the 4.3.1 app didn't do the trick for me. Now I'm down to 4.1 which is working like a charm :D
DanielMalmgren
Postby DanielMalmgren » Wed Nov 05, 2014 8:03 pm
I think this will finally get a solution in Lollipop: https://plus.google.com/+JeffSharkey/posts/4kxjY9JFemL
/Daniel
DanielMalmgren
Postby jammer » Sat Nov 22, 2014 1:17 am
I sure hope so!
jammer
Postby phokus » Tue Mar 17, 2015 8:51 pm
I didn't have this problem until my HTC One M8 updated to Lollipop last week. I installed apk 4.1 and it works again.
phokus
Postby killj0y » Sun May 10, 2015 5:19 am
This might also be related to the fact that starting on KK android doesn't allow writing to the sd card by apps just willy nilly and is more locked down for "security". I had issues with several apps including dsub but fixed it in my case by removing that new "feature". The downside is you must be rooted for this. I imagine the reason the solution mentioned previously works because the app is given permission to write to certain folders only but depending on the version these folders vary.
killj0y
Postby semkd » Fri Oct 23, 2015 12:46 pm
Access to SD card is blocked again on Android 5.1.1 at least for Sony Z3
semkd
Previous
