Android client loops first song
Postby GJ51 » Tue Nov 02, 2010 8:35 am
alphawave7 wrote:
GJ51 wrote:
alphawave7 wrote:
GJ51 wrote:
alphawave7 wrote:Like so many things...when they 'just work', they seem bulletproof. When a pesky issue crops up, suddenly it's 'buggy'. I tend to agree that basic functionality across the iPhone/Android sets should be priority, and even that is a challenge with the disparity in units, OS versions, and firmware being used. For those that have bulletproof installs, naturally they want features...it's a developer conflict older than I am: 'it is what it is". :)
I'd like to know why the "quote" feature isn't working for me on the forums. Annoying, but definitely won't stop me from posting. :mrgreen:
I want this elevated to the top! :oops:
Interesting...the code is accurate, so its something else. I was wondering why you were just copy/pasting!! :P :shock: :lol:
Truly annoying. That's it, I'm done posting. I'll take my forum participation to a site that works! :roll:
AHA! You have BBCode disabled in your profile settings, I suspect. When I went to edit your post, I noticed BBCode was disabled for yours, but not mine. :)
edit: unchecked 'Disable BBCode' on that post, and 'whallah'...
OK ... I'll hang out a little while longer. :lol:
Thanks Alphawave7!
Postby GJ51 » Fri Nov 05, 2010 3:20 am
ver. 1.8.1 still repeats 1st track.
Postby john6555 » Tue Nov 09, 2010 2:30 am
Yes, quite an annoying bug.
john6555
Postby lyric911 » Tue Nov 09, 2010 11:38 am
MediocreFred wrote:I have a 16GB microSD card and don't really use all that space for anything else. My understanding of the purpose of the cache is to store downloaded songs. When I am offline (either on an airplane, or in a remote area without mobile access), I play the cached songs using the cube player.
GJ51 wrote:Why do you have your cache set so high? What size SD card do you use?
Have you tried using the 500 setting? It works just fine for me.
My cache is 10 GB for the same reason.
lyric911
Postby GJ51 » Tue Nov 09, 2010 11:51 am
I've bumped mine up as well as it's a good idea if you think you'll be without a signal for an extended time. The original dialog was primarily focused on trying to pinpoint possible causes of stuttering that some were experiencing.
It now appears that cache size is not a factor with the stuttering problem.
I have found 2 instances where the issue was poor upload speed and another where the cause was p2p blocking that was blocking the user's ISP.
Postby RevMen » Tue Nov 09, 2010 5:36 pm
Same issue here on my G2 (from HTC).
RevMen
Postby Jleckrone » Thu Nov 11, 2010 6:31 pm
I also have this problem with a droid incredible. I think the issue occurs when it starts playing a track before it's completely finished downloading. Hope that helps!
Jleckrone
Postby GJ51 » Thu Nov 11, 2010 7:04 pm
That's what I found as well, when I tested some sites that didn't have adequate upload speed.
The first track repeats on my EVO 4G no matter what, but after that I'm OK when on a site with enough bandwidth. When you get on a slow site the player will repeat the previous track if it calculates that the next track wil not be able to play to the end at the current download speed.
Postby GJ51 » Mon Nov 15, 2010 9:48 pm
ver. 1.8.2 still repeats 1st track.
Online only!
Offline, queued music plays properly, i.e. first track does NOT repeat.
Go figure ... :?:
Postby monst » Wed Nov 17, 2010 6:05 pm
Same issue with my EVO, wonderful product, pesky bug.
monst
Postby simpdawg » Wed Nov 17, 2010 6:16 pm
still seeing this issue, but it seems to be mainly happening when the song hasn't completely downloaded, which is in line with others' experiences.
running stock froyo 2.2 on htc incredible on verizon, subsonic v1.8.2 on phone, paid server 4.1 build 1802
simpdawg
Postby sindre_mehus » Wed Nov 17, 2010 8:01 pm
Hi guys,
Sorry for the delay. I'll definitely look into this issue.
It could be a bit difficult to figure out, since I'm not seeing this issue on my phones (Nexus One 2.2 and HTC Hero 2.1).
If someone could email (sindre@activeobjects.no) me the Android log from the phone when this happens, it would be most helpful.
Postby monst » Wed Nov 17, 2010 8:09 pm
The Subsonic app basically wont continue to the next song till its fully downloaded. If the next song in que is fully downloaded it wont repeat. It should instead allow the playing of the partial downloaded song next in que. I will try and provide the android.log here shortly.
monst
Postby monst » Wed Nov 17, 2010 8:24 pm
logs sent.
monst
Postby sindre_mehus » Thu Nov 18, 2010 12:03 pm
@monst: Thanks, but I couldn't see anything relevant from that log.
Best thing would be to do an "adb logcat" from an attached computer, and capture everything that happens (including before the songs start playing the first time, up until it starts repeating).
