"Host name may not be null" in app
Re: "Host name may not be null" in app
Postby bionicdude » Fri Aug 31, 2012 9:23 am
Not a fix, but a workaround...
I set up a pptp vpn on my router.
Android has built in vpn capability, so I just vpn into my home network and connect "locally" to the server. This works even on 3g.
Not ideal, but at least I get to use the server.
Edit: sgs 2 using ICS
bionicdude
Postby Ramenator » Fri Aug 31, 2012 2:22 pm
GJ51 wrote:I've got everything working fine on my SIII using a variant of the DSub app.
Have you tested the Dsub app on the demo server?
What king of phone?
It's a Galaxy Note running CM9.
I tried this in the wee hours of the night so I don't recall if I tried the demo server.
I thought the issue was related to my .no-ip.org domain having the hyphen in the URL but I even tried my .subsonic.org hostname without any success.
Ramenator
Postby GJ51 » Fri Aug 31, 2012 2:49 pm
If you're inside your network on wifi, try the local address, ie. 192.168.1.xxx:4040.
Postby Ramenator » Fri Sep 07, 2012 1:50 am
Like the original problem states, it works over WiFi but not over the cellular data network.
Cheers,
Ramenator
Postby GJ51 » Fri Sep 07, 2012 2:59 am
Then test to see if your phone works on the demo server and check to see if the port to your host is open at http://canyouseeme.org
I apologize for not remembering every detail of every post that I answer. especially on the ones where 2 or three users may be chiming in on the same issue and only give feedback on an avg. of once per week.
Good luck with your issue, I won't bother you with any further suggestions.
Postby Ramenator » Tue Sep 25, 2012 10:45 pm
GJ51 wrote:Then test to see if your phone works on the demo server and check to see if the port to your host is open at http://canyouseeme.org
No need. Seems like this issue was fixed with the latest release on the Google Play Store.
What's New
What's in this version:
o Fix "Host name cannot be null" error on ICS.
o Support Bluetooth play/pause buttons on ICS.
o Improve caching of artist list.
o Ensure readable text in notification when background is dark.
o Fix crash when using fast scrolling.
o Enable fast scrolling of playlists, search results and songs.
Thanks anyways!
Ramenator
Postby sindre_mehus » Wed Sep 26, 2012 1:20 pm
It would be great if someone could confirm that this error is really fixed in version 3.4 of the Android app.
Postby bionicdude » Wed Sep 26, 2012 1:50 pm
Works now on sgs2 ICS
Thanks.
bionicdude
Previous
