http://www.4shared.com/music/6j5gCQJq/recit24bit.html
but some abuse the privilege!
but some abuse the privilege!I did a few tests of my own and all my players did play the track but some seemed to have problems with the first playincluding WMP - go figure
WMP, VLC, & Winamp played but stuttered on first play - WMP needed the most coaxing
Subsequent plays np![]()
Foobar, Mediamonkey, MPC played np![]()
Subsonic - silence![]()
Guessing here but as the file ext gives no clue to the Mediaplayer (normal wma, lossless16bit, lossless24bit -all wma) it needs to start streaming the file
before it can load/configure the codec - hence stutter on first play
but some abuse the privilege!BKKKPewsey wrote:Go here and grab the latest ffmpeg static build.
Unzip the file and go to the bin folder - copy the ffmpeg.exe file to your subsonic/transcode directory.
BUT rename the original ffmpeg.exe first or move it somewhere safe
Then test & hope
If it doesn't work then you can revert back to the original ffmpeg.
The other thing you could do is re-code the files to flac which play np in SS and are still lossless but that depends on how many files you have.
There will now be a short intermission - ice-cream & pop corn are available at the kiosk
GJ51 wrote:I'm not on a NAS
pac wrote:To rectify the issue then... should I remove the windows install ver of ss
but some abuse the privilege!Step 1: ffmpeg -i %s -f wav -ar 44100 -ac 2 -
Step 2: lame --preset cbr %b --tt %t --ta %a --tl %l -S - -
but some abuse the privilege!Users browsing this forum: No registered users and 15 guests
