readyshare network connection
Re: readyshare network connection
Postby shenery » Wed Sep 19, 2012 12:31 am
One quick question if your still with us lol
Im getting an error in the browser when i try to add my harddrive.
Do you know what that could be?
Edit:
No error after a reboot but when i point to the drive and select scan, normally i get a thing in the right hand side saying scanning but this time i have nothing.
shenery
Postby GJ51 » Wed Sep 19, 2012 1:24 am
Do the files show?
Postby shenery » Wed Sep 19, 2012 1:28 am
Nah no files. just says scanning and could take several minutes.
nothing happens. normally it has a thing in the right hand side saying scanning right?
shenery
Postby GJ51 » Wed Sep 19, 2012 1:52 am
It does on mine, but we may not be using the same theme and that could just be an anomaly.
Set up a music directory on the host hard drive and just put a couple folders in it to see if it works with that.
Are you using the local drive letter for the usb drive instead of the share name? If the drive shows as a local drive as it should, the your entry in Settings/Music Folders should be X:\Music or something similar.
Postby shenery » Wed Sep 19, 2012 2:06 am
It syncs the files in c:/music but doesnt like anything else
Edit.
I took your advice and plugged in the drive to the pc instead of the router
shenery
Postby GJ51 » Wed Sep 19, 2012 2:13 am
Does the drive show up in windows explorer as a local drive, can you access and read the files in explorer?
Postby shenery » Wed Sep 19, 2012 2:15 am
Yeah i can access it in windows. Play files off it as well.
Ive also tried what you said earlier to uninstall java and subsonic but that didnt work either
shenery
Postby GJ51 » Wed Sep 19, 2012 2:17 am
Got me baffled.
Did you edit the subsonic service permissions? For this setup you should just use the local account, not a logon account like what was needed before.
Did I mention that I hate usb drives? Does this drive use NTFS?
Postby shenery » Wed Sep 19, 2012 2:20 am
Me too! Lol. Im sooooooo close :(
Could it be to do with permissions for subsonic. Mind it set them up for the readyshare drive?
shenery
Postby GJ51 » Wed Sep 19, 2012 2:22 am
That's probably it, just use the local account like in the default setup.
Postby shenery » Wed Sep 19, 2012 2:25 am
Not really sure what you mean
Edit:
Nah its not that. its set up for local
shenery
Postby GJ51 » Wed Sep 19, 2012 2:38 am
Read the procedure for editing the Subsonic service in the Monroe World Tutorial again, Follow the instructions, but reverse the edit and set the service back to using a local account logon like it was before you edited the account you put in to access the network share.
I think you actually did this not too long ago, Just reverse the process. If that's not it I have no idea what is going on.
Postby shenery » Wed Sep 19, 2012 2:39 am
i just followed that. it was set up for local anyway
shenery
Previous
Users browsing this forum: Google [Bot] and 20 guests
