Video streaming gives bad ratio
Postby nowid50 » Mon Aug 13, 2012 4:41 pm
I've been using Subsonic for quite a time and I found that there is a bad ratio while transcoding and I don't have any clues to fix it.
Let me show you, here is the (kinda) original frame :
The output :
Is there anyone that can help fix this ?
Thanks in advance :)
nowid50
Re: Video streaming gives bad ratio
Postby GJ51 » Mon Aug 13, 2012 9:12 pm
Right click on the player bar - 3rd option allows you to toggle stretching options.
Postby nowid50 » Mon Aug 13, 2012 10:19 pm
Oh thanks, I didn't know that. :)
But isn't there a way to make transcoding aware of the ratio of the input movie ? Even if that saves one second, it is still more user friendly. :D
nowid50
Postby GJ51 » Tue Aug 14, 2012 3:01 am
I think later versions of JW Player also adapt to the video better. You can download the latest version from:
http://www.longtailvideo.com/players/jw-flv-player/
and just drop it in the right directory. The instructions are in here somewhere.
