Everything works except Play/Queue button
Postby theG » Fri Sep 14, 2012 7:49 pm
I have Subsonic 4.6 installed (stand-alone) on my seedbox but I have one problem: I cannot add songs (bottom: playlist/queue)
When I press the Play button, the + to add songs (queue), Play all, Play random or Add all it does absolutely nothing.
I can create a playlist, add songs to it, save the playlist, then load it. No problem here.
The playlist and tracks load like they should and they play like they should, but yeah, playing a song from the album track list doesn't work.
Any idea what could cause that? Permissions on a specific file or folder perhaps?
What file is the queue written to? Perhaps that's the problem?
theG
Re: Everything works except Play/Queue button
Postby BKKKPewsey » Fri Sep 14, 2012 11:05 pm
Thats a weird one :?
I am wondering if your user a/c has got somewhat corrupted.
Try creating another user and see if that works.
Postby hakko » Sat Sep 15, 2012 5:42 am
You could also delete the jetty directory in C:/subsonic (or equiv), go back to the artist view and see if it helps. Sometimes one of the generated html files get corrupt, resulting in odd errors like this.
MusicCabinet developer
hakko
Postby theG » Mon Sep 17, 2012 1:34 am
BKKKPewsey wrote:Thats a weird one :?
Ah, that worked. I was using the admin account and used it to share playlists, I guess I'll just use another account instead then. Don't know why it wouldn't work with that account, but I can surely use another account. Thanks
theG
