4.7 album song order change? WAVE is wrong, FLAC is correct
Postby Kraut » Tue Sep 18, 2012 4:06 am
I just updated to 4.7 and noticed the song order in the albums is alphabetical, instead of the correct album order #'s, as it used to be. How can I change it back to the original album order, not alphabetical? Thanks
Kraut
Re: 4.7 album song order change?
Postby Kraut » Sat Sep 22, 2012 4:44 pm
Okay, I noticed an anomaly. Most all my song are in WAVE format. These song are automatically organized in the album alphabetically. I have a couple of albums which are in FLAC format. Those albums are organized correctly: the order the album is on the CD.
So, anyone know how to get my WAVE formatted songs to be organized correctly? And no, I am not going to convert my whole server to FLAC.
Kraut
Re: 4.7 album song order change? WAVE is wrong, FLAC is cor
Postby BKKKPewsey » Sun Sep 23, 2012 2:07 pm
FLAC have tags which SS can read, wav files do not so SS has to revert back to an alphabetical sort.
Postby Kraut » Sun Sep 23, 2012 4:27 pm
BKKKPewsey wrote:FLAC have tags which SS can read, wav files do not so SS has to revert back to an alphabetical sort.
I understand that, but this problem just started happening with the upgrade to 4.7. I have always had my music in WAVE format in which the songs were not listed alphabetically.
Kraut
Postby BKKKPewsey » Sun Sep 23, 2012 8:50 pm
4.7 uses the tag data - 4.6 used the folder structure ( simplified explanation :roll: )
Postby Kraut » Sun Sep 23, 2012 9:49 pm
BKKKPewsey wrote:4.7 uses the tag data - 4.6 used the folder structure ( simplified explanation :roll: )
Anyway to use the old way without going back to 4.6?
Kraut
Postby Kraut » Thu Oct 04, 2012 3:44 pm
Anyone?
Kraut
Postby bushman4 » Thu Oct 04, 2012 3:52 pm
Short answer: No. No way to revert without rolling back to version 4.6.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Kraut » Thu Oct 04, 2012 3:57 pm
bushman4 wrote:Short answer: No. No way to revert without rolling back to version 4.6.
Glenn
Bummer. I like 4.7 load time for browsing on phones, but the song order bugs me. I guess I could just switch the songs back to uncompressed FLAC.
Kraut
Postby bushman4 » Thu Oct 04, 2012 4:02 pm
Why not just compressed FLAC? It is loss-less... the only "cost" is CPU time to transcode them, which you are paying now anyway to transcode the WAV files to MP3...
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Kraut » Thu Oct 04, 2012 4:06 pm
bushman4 wrote:Why not just compressed FLAC? It is loss-less... the only "cost" is CPU time to transcode them, which you are paying now anyway to transcode the WAV files to MP3...
Glenn
If I remember right, certain web browsers gave me trouble with FLAC, that is why I switched a while ago. Maybe I will give it a try again.
Kraut
