subsonic android app error
Postby ma_guinea » Thu Sep 27, 2012 8:47 pm
I can connect to a friend's server no problem but when i try to connect to My own server i get time out errors. My phone will connect to my subsonic server through the browser (both through my local network and from outside my network)...its just the android app that doesn't seem to like my server. If there was a problem with the server is have thoughy I wouldnt be able to connect full stop...?
ma_guinea
Re: subsonic android app error
Postby bushman4 » Fri Sep 28, 2012 12:16 pm
Have you paid for and registered a subsonic license? If not, your server would only allow API (remote app) connections for the first thirty days after you install it.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby ma_guinea » Fri Sep 28, 2012 3:44 pm
Hi Glenn. Yes I have, quite a while ago, and have never had issues connecting to my server using xxxxxx.subsonic.org from a web browser (be it on my phone, tablet or a computer).
ma_guinea
Postby bushman4 » Fri Sep 28, 2012 3:53 pm
You never will have issues connecting to the web interface. it is only the RestAPI that needs activation.
Can you verify that subsonic shows that it is registered in the web interface?
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby ma_guinea » Fri Sep 28, 2012 4:09 pm
Dear Subsonic donor,
Many thanks for your kind donation to Subsonic!
Please find your license key below.
Email: xxxxxxxxxxxxxxxxxxxxxxx
License: xxxxxxxxxxxxxxxxxxx
To install the license, click the "Donate" link in the top right corner of the Subsonic web interface.
More info here: http://subsonic.org/pages/getting-started.jsp#3
Thanks again for supporting the project!
Best regards,
Sindre Mehus
ma_guinea
Postby ma_guinea » Fri Sep 28, 2012 4:15 pm
Here is the web interface showing it is activated.
ma_guinea
Users browsing this forum: No registered users and 42 guests
