UNC paths ok, DFS paths not working :(
Postby NiknakSi » Tue Oct 30, 2012 7:59 am
Hi
I've just gone through the process of creating a new domain user account for the Subsonic service and reconfiguring the service entry to run under this account. The user has correct access to the UNC and DFS paths I'm trying and if I try a normal UNC path directly to a single machine it's all ok. However, if I try the DFS path that I'd rather use then Subsonic spits out the following log info:
[30/10/12 07:46:51 GMT] INFO MediaScannerService Starting to scan media library.
[30/10/12 07:46:51 GMT] INFO MediaScannerService Scanned media library with 0 entries.
My UNC path that works is: \\[machine name]\Music\Albums
My DFS path that does not work is: \\[domain name]\SAN\Media\Music\Albums
Is this a Subsonic limitation some how? Is it possible to enable more verbose logging to try and discover where the problem lies?
Many thanks :)
..Simon
NiknakSi
Re: UNC paths ok, DFS paths not working :(
Postby BKKKPewsey » Tue Oct 30, 2012 9:56 pm
I know that SS does not work with mapped drives so its no surprise that it will have problems with DFS paths :(
Postby tnt533 » Tue Nov 13, 2012 6:22 am
I use subsonic with a mounted network drive running on Ubuntu server with no issues. My guess would be it is because subsonic is dealing with multiple physical drives as a single logical drive and doesn't like it. Another thought is authentication. Accessing a resource on the domain level requires it touch your DC. A UNC directly to a resource without specifying a domain may not. I'm on the Cisco side so I may be wrong.
tnt533
Postby tnt533 » Tue Nov 13, 2012 6:27 am
One more thing. Did you make sure to enable ldap authentication on the advanced tab in subsonic?
tnt533
Users browsing this forum: No registered users and 58 guests
