Port forwarding works, subsonic.org url does not [Resolved]
Postby DGalt » Wed Oct 31, 2012 5:36 am
I have Subsonic installed on an unRaid media server, and I've configured port forwarding using 4040 as my port (not using the automatic configuration...set a static IP for my server and enabled port forwarding for that port within my router). If I go to http://<my-external-ip>:4040 (external IP determined using http://www.canyouseeme.org/), I get to the Subsonic login, as one would expect.
However, if I try to use the provided web address (http://danbury.subsonic.org), the connection times out. Within the administration page, though, it says everything is working fine (Status: danbury.subsonic.org responded successfully.)
Any ideas what's going on here?
DGalt
Re: Port forwarding works, subsonic.org url does not
Postby bushman4 » Wed Oct 31, 2012 12:19 pm
Working from here...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby DGalt » Wed Oct 31, 2012 2:00 pm
huh, yeah now it's working. I notice now that the correct IP address is being displayed too when I go to the url (it was using something else before). Odd...oh well, as long as it's working.
DGalt
Users browsing this forum: No registered users and 62 guests
