Android ads not removed [Resolved]
Postby slycurgus » Thu Nov 01, 2012 6:17 am
Hi, after the recent update to the android app, I paid to disable ads in the player. The next day, an update was released to "[fix] problem with purchase not being registered", which I assume is to do with the ad removal purchase. Even after updating, ads still appear in the player, and if I click the "remove ads" link on the main screen of the app, the Play Store informs me that I've already purchased the item.
I'm wondering if uninstalling and reinstalling the app might fix things, but thought I should ask here first to confirm. Is there something I can do to remove the ads?
thanks in advance.
slycurgus
Re: Android ads not removed
Postby bushman4 » Thu Nov 01, 2012 12:54 pm
Yes, remove and reinstall. When reinstalled, the app will see that the ad-free option has been purchased and will hide the ads.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby slycurgus » Thu Nov 01, 2012 7:42 pm
Thanks for the reply, everything went smoothly and the ads are removed.
My only real worry was that the tracks I had cached would be lost and I'd have to reload them, but they seem to have survived just fine, so all is well!
Thanks again. Do I need to do anything further with this thread (mark it 'solved', close it, or the like)?
slycurgus
