m4b files do not show up in interface
Postby ajkessel » Sun Nov 11, 2012 4:56 pm
I added m4b to the list of extensions in the general configuration and rescanned my collection. However, no m4b files shop up in the web or iSub interface. Is there anything else I need to do to make m4b files available from a Subsonic server?
ajkessel
Re: m4b files do not show up in interface
Postby BKKKPewsey » Sun Nov 11, 2012 8:00 pm
As a test I added (from a previous thread) some wv files to my test server (4.7)
Even after scanning they still wouldn't appear (containing directory was listed in left frame)
I then added some album art to the folder and "poof" they appeared :?
So make sure you have some album art in the folder - and see if that makes 'em show up.
Postby ajkessel » Mon Nov 12, 2012 1:51 am
I added folder.jpg and some AlbumArt*.jpg files to the same folder with the m4b audiobook and re-scanned. Still doesn't appear in search or index.
ajkessel
Postby BKKKPewsey » Mon Nov 12, 2012 12:06 pm
Another thing that I did, which you may have but not mentioned, was to add the files types to the transcode settings.
Unfortunately I do have any m4b files on server to test.
Postby ajkessel » Mon Nov 12, 2012 5:43 pm
I have m4b defined in transcode already. Still no luck.
ajkessel
Postby daily-freak » Tue May 13, 2014 7:14 am
I know this is an old thread, but currently I'm having the same Problem. m4b Audiobooks don't show ub in the interface. On the left column I see the artis and in the content-Area I see the Book as Album. But when I play it nothign happens and when I open it there is nothing shown in it. Just empty space... The files themself are tagged correctly and shown perfectly in iTunes for example.
Greetings
daily-freak
Postby daily-freak » Wed May 14, 2014 10:40 am
>Again< solved the problem by myself because this forum seems to be f***** dead.. Very sad..
You have to do a few things:
* In Settings/Transcoding Add this Transcoding:
Convert from: m4b
Convert to: mp3
Step 1: ffmpeg -i %s -f wav -
Step 2: lame -b %b - -
* In Settings General add m4b to Music Files
* In the folder where the m4b-file is stored in add a corresponding folder.jpg
* Rescan library
* The m4b-File will be shown an playable!
daily-freak
Postby ajkessel » Fri Jun 06, 2014 7:03 pm
None of these solutions work for me, including the most recent post by daily-freak. I can't figure out how to troubleshoot this--shouldn't there be a log entry somewhere indicating why all the m4b files are skipped even though they are supposed to be scanned? Any further ideas?
ajkessel
Postby ajkessel » Fri Jun 06, 2014 7:19 pm
I should note that all the m4b files do show up in the 'file' table; just not in the user interface.
ajkessel
Users browsing this forum: No registered users and 101 guests
