How to install Subsonic in an ISPConfig website
Postby mroppolo » Sat Dec 15, 2012 8:15 pm
Hello all -
I have searched for a solution and cannot locate anything helpful.
I would like to create a music streaming website on my ISPConfig server using Subsonic. I cannot use http://localhost:4040. Instead, my URL will need to look like http://mstream.mysite.com
I thought installing Tomcat6 and unzipping the standalone files into the new website's directory would work, but no joy.
I believe the web server is looking for a start page (something similar to index.html but in a Java format). When I go to the website, I receive a 403 Forbidden error.
Any ideas ?
Thanks !!
Mike
mroppolo
Re: How to install Subsonic in an ISPConfig website
Postby bushman4 » Sat Dec 15, 2012 10:11 pm
Don't unzip the file.
Install tomcat 6.
Put the subsonic.war file in the webapps directory.
Restart the Tomcat service.
Tomcat will then deploy the war file as it needs to.
Watch /var/subsonic/subsonic.log to see if it starts up correctly.
Then access it via http://Your.Host.Name/subsonic
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby mroppolo » Sun Dec 16, 2012 12:43 am
Interesting, I did copy the war file to webapps. I restarted Tomcat and checked the logs. Nothing obviously wrong (no errors), so I think it may be running, but http://mywebsite.com/subsonic still doesn't render anything.
The problem may be I need to get ISPConfig to point the website files in /var/lib/tomcat6/webapps/subsonic. The ISPConfig website directory is located in /var/www/clients/client1/web3/web.
Under ../webapps/subsonic, what file is the index page for the site ? Maybe I can create a symbolic link ?
mroppolo
Postby mroppolo » Sun Dec 16, 2012 6:04 pm
Hello all -
I'm still looking for help on this issue. Here is the log contents from today (all looks well to me):
[2012-12-15 13:54:00,477] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Sun Dec 16 03:00:00 EST 2012
[2012-12-15 13:54:00,477] INFO MediaScannerService - Media library never scanned. Doing it now.
[2012-12-15 13:54:00,481] INFO MediaScannerService - Starting to scan media library.
[2012-12-15 13:54:00,732] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Dec 15 13:59:00 EST 2012
[2012-12-15 13:54:00,982] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-12-15 13:54:00,982] INFO MediaScannerService - Marking non-present files.
[2012-12-15 13:54:00,995] INFO MediaScannerService - Marking non-present artists.
[2012-12-15 13:54:01,009] INFO MediaScannerService - Marking non-present albums.
[2012-12-15 13:54:01,012] INFO MediaScannerService - Completed media library scan.
[2012-12-15 13:54:01,027] INFO PlaylistService - Starting playlist import.
[2012-12-15 13:54:01,027] INFO PlaylistService - Completed playlist import.
[2012-12-15 13:54:01,027] INFO PlaylistService - Starting playlist statistics update.
[2012-12-15 13:54:01,028] INFO PlaylistService - Completed playlist statistics update.
[2012-12-15 13:54:03,862] INFO NetworkService - Deleted port mapping for port 80
[2012-12-15 13:59:00,727] INFO PodcastService - Starting scheduled Podcast refresh.
[2012-12-15 13:59:00,729] INFO PodcastService - Completed scheduled Podcast refresh.
[2012-12-16 03:00:00,477] INFO MediaScannerService - Starting to scan media library.
[2012-12-16 03:00:00,541] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-12-16 03:00:00,541] INFO MediaScannerService - Marking non-present files.
[2012-12-16 03:00:00,543] INFO MediaScannerService - Marking non-present artists.
[2012-12-16 03:00:00,547] INFO MediaScannerService - Marking non-present albums.
[2012-12-16 03:00:00,569] INFO MediaScannerService - Completed media library scan.
[2012-12-16 03:00:00,586] INFO PlaylistService - Starting playlist import.
[2012-12-16 03:00:00,586] INFO PlaylistService - Completed playlist import.
[2012-12-16 03:00:00,586] INFO PlaylistService - Starting playlist statistics update.
[2012-12-16 03:00:00,587] INFO PlaylistService - Completed playlist statistics update.
Here's a recap of the issue:
http://mywebsite.com/subsonic still doesn't render anything. I believe the problem may be getting the website located in /var/www/clients/client1/web3/web to point to the Subsonic files located in /var/lib/tomcat6/webapps/subsonic.
Can someone tell me what file is the site landing page ? Perhaps it will work if I can create a symbolic link from the website to the Subsonic files.
Thanks !
Mike
mroppolo
