Failed to test web address. Cannot assign requested address
Postby enaba » Fri Dec 21, 2012 6:00 pm
Subsonic 4.7 (build 3106) – September 12, 2012
I am having issue with Subsonic after formatting my PC, its giving me this error when i try to register a domain.
ramyenab.subsonic.org
Failed to test web address. Cannot assign requested address: connect (BindException)
Here is the log
[12/21/12 9:42:09 PM GST] INFO DaoHelper Checking database schema.
[12/21/12 9:42:10 PM GST] INFO DaoHelper Done checking database schema.
[12/21/12 9:42:10 PM GST] INFO VersionService Resolved local Subsonic version to: 4.7
[12/21/12 9:42:11 PM GST] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Dec 22 03:00:00 GST 2012
[12/21/12 9:42:11 PM GST] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Dec 21 21:47:11 GST 2012
[12/21/12 9:42:34 PM GST] INFO NetworkService Successfully forwarding port 4040 and port 4443.
[12/21/12 9:45:02 PM GST] WARN VersionService Failed to resolve latest Subsonic version.
[12/21/12 9:45:36 PM GST] WARN NetworkService Failed to register web address.
[12/21/12 9:45:36 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:45:43 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
[12/21/12 9:46:31 PM GST] WARN NetworkService Failed to register web address.
[12/21/12 9:46:31 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:46:38 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
[12/21/12 9:47:05 PM GST] WARN NetworkService Failed to register web address.
[12/21/12 9:47:05 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:47:11 PM GST] INFO PodcastService Starting scheduled Podcast refresh.
[12/21/12 9:47:11 PM GST] INFO PodcastService Completed scheduled Podcast refresh.
[12/21/12 9:47:12 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
[12/21/12 9:48:39 PM GST] WARN NetworkService Failed to register web address.
[12/21/12 9:48:39 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:48:46 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
[12/21/12 9:48:48 PM GST] WARN NetworkService Failed to unregister web address.
[12/21/12 9:48:48 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:48:55 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
[12/21/12 9:48:58 PM GST] WARN NetworkService Failed to register web address.
[12/21/12 9:48:58 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:49:05 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
[12/21/12 9:49:14 PM GST] WARN NetworkService Failed to register web address.
[12/21/12 9:49:14 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:49:21 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
[12/21/12 9:49:47 PM GST] WARN NetworkService Failed to register web address.
[12/21/12 9:49:47 PM GST] WARN NetworkService Failed to test web address.
[12/21/12 9:49:54 PM GST] INFO NetworkService Successfully forwarding port 4440 and port 4443.
Can anyone help please
enaba
Re: Failed to test web address. Cannot assign requested addr
Postby enaba » Sat Dec 22, 2012 7:47 pm
can someone help me please
enaba
Postby enaba » Sun Dec 23, 2012 12:34 pm
Help anyone ??
enaba
Postby hakko » Sun Dec 23, 2012 1:01 pm
BindException normally means that you have something else running on the port you're trying to use. For example that you're running a Tomcat server which listens on port 8080, and then you start a Jetty server which also tries to listen on port 8080. One port can only be used by a single program. So I'd check what port you're trying to assign and then check if another process is already using that port.
MusicCabinet developer
hakko
Postby enaba » Sun Dec 23, 2012 6:17 pm
thank you so much, i honestly have no idea what is blocking it.
I just made a restart and it works.
enaba
