able to download the song, if the URL is used in address bar
Postby sandy73 » Fri Jan 18, 2013 9:34 am
I am working on a website which plays songs from the streaming server, for which I have used gigapros. I installed the subsonic on my gigapros server. Everything works perfectly fine but for streaming I have to feed the stream URL (For Ex. http://my-server:4040/rest/stream?u=use ... yapp&id=24) to my jplayer.
The songs also works fine. But the problem is that, I can get the stream URL from the Firebug or view source. If I paste this URL in the address bar, I can download the song. How can I prevent this from happening?
Is there something I am missing ?
Is there any other approach to this ? I need help ASAP please.
sandy73
Re: able to download the song, if the URL is used in address
Postby BKKKPewsey » Fri Jan 18, 2013 5:19 pm
Its impossible to stop recording any stream (SS or otherwise).
If it can be played on the pc then you can record it. There are a number of tools out that that can capture and record streams, you have just found one option.
Postby sandy73 » Mon Jan 21, 2013 5:34 am
but is there any other way to send the url to the subsonic API to stream. I dont want people to be able to download, if they have the URL. In other words can I encrypt the URL and send it to subsonic to stream the song ?
sandy73
